So I recently started noticing horrible lag in-games. Decided to check my temps and my CPU was at 75C. When my CPU hits 75C it sets the multiplier from 19.5 to 7. Pretty sure CPUs are supposed to run like 30-50.
I opened my case, removed dust and while idle, temps were 45, slowly rising. Now the temps are 45-60 at idle. I opened a youtube video and the temps went to 75.
Sorry if this thread is messy or unclear, but my temps aren't right and I need help. I think its the thermal paste but I have no idea really.
My CPU: AMD FX-4130 Quad-Core Processor
Here is the graph when I opened a video (http://gyazo.com/a3308bf1e7997675f04abaadd59b1a42)
https://linustechtips.com/topic/269490-sudden-overheating/
New aftermarket cooler and new thermal paste/grease. Also maybe a new case (if you have something with bad cable management, poor cooling / air throughput, PSU on top).
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/269490-sudden-overheating/#findComment-3658635
Try replacing the thermal paste with MX-4 and remount the cooler.
Make sure you clean all the old thermal paste off using alcohol from the CPU and the cooler.
If you can afford it, upgrade to a 212 evo cooler, it is much better.
https://linustechtips.com/topic/269490-sudden-overheating/#findComment-3658639
Thanks for your help guys. I already have a cooler master cooler, it has to be the thermal for sure.
https://linustechtips.com/topic/269490-sudden-overheating/#findComment-3660711
Would anyone mind taking a look if I post a picture of the current thermal paste? Looks bad to me.
Sure, go ahead. We can have a look at this bad body for ya.
Take a picture of the paste on both the CPU and the bottom of the heatsink.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/269490-sudden-overheating/#findComment-3682556
  • 2 weeks later...
  • 1 month later...
I replaced it and the problem is still there. I'm clueless now.
What did you replace it with? And are you certain your heatsink has proper contact with your IHS?
I have finally moved to a desktop. Also my guides are outdated as hell.
THE INFORMATION GUIDES: SLI INFORMATION || vRAM INFORMATION || MOBILE i7 CPU INFORMATION || Maybe more someday
https://linustechtips.com/topic/269490-sudden-overheating/#findComment-4127708
Get aftermarket cooler and new thermal paste..
And if future you should go with Intel :)
https://linustechtips.com/topic/269490-sudden-overheating/#findComment-4127807
The way its attached is pretty simple, I'm more than certain you cant even put it on wrong.
Yes, but while unlikely, it's possible that your heatsink is not flush with the IHS.
https://linustechtips.com/topic/269490-sudden-overheating/#findComment-4127995
I turned the heatsink the otherway and tried its on perfectly, still occurs.
http://gyazo.com/d658bb2a7e34c948993eed8412208ba0
41 temp at system startup, 2 seconds later its 49. I start up chrome and start a stream on source quality.
Get HWmonitor running and check your PSU voltage outputs. If the CPU is sick it might be pulling too much or too little. Or the PSU is sick and not giving it enough juice. Worth a check to rule it out.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/269490-sudden-overheating/#findComment-4136208
