Gigabyte HD 7970 SOC flash to Ghz edition and some other thoughts
samuel
First of all, I don't have it yet. It's coming the day after tomorow.
But I'm already thinking about flashing it to Ghz edition, just to be more...modern! (Boost and such). BUT, will it work? It's not a reference design, no idea of the revision, all I know is that I have a very handy bios switch...
Second of all, two fans have lost one and two blades respectively. Should I replace them all 5 fans? The owner said it's working just fine... And I can return it within three days no questions asked. $200, a very good deal in my area.
I will not overclock it at all I think. My 500W Sirtec (The PSU in signature had a nasty surpise for me,,,)will not be that happy with the new guest..I  actually plan to undervolt this beast while keeping GHZ edition clocks....  AAAND there is a perfect mach...the lenght of the video card is exactly the max lenght supported by my Z11...some bending planed!
I apologise for bragging, I mostly need to know about the bios flashing.
Les noisy fans : 7970-soc-windforce-5x,5-4-344920-22.jpg
FX8320 4.2Ghz@1.280v& 4.5 Ghz Turbo@1.312v Thermalright HR-02/w TY-147 140MM+Arctic Cooling 120MMVRM cooled by AMD Stock Cooler Fan 70MM 0-7200 RPM PWM controlled via SpeedfanGigabyte GA990XA-UD3Gigabyte HD 7970 SOC@R9 280X120GiBee Kingston HyperX 3K2TB Toshiba DT01ACA2001TB WD GreenZalman Z11+Enermax 140MM TB Apollish RED+2X Deepcool 120MM and stock fans running @5VSingle Channel Patriot 8GB (1333MHZ)+Dual Channel 4GB&2GB Kingston NANO Gaming(1600MHZ CL9)=14GB 1,600 Jigahurtz 10-10-9-29 CR1@1.28VSirtec High Power 500WASUS Xonar DG, Logitech F510Sony MDR-XD200Edifier X220 + Edifier 3200A4Tech XL-747H 3600dpiA4Tech X7-200MPdecent membrane keyboardPhilips 236V3LSB 23" 1080p@71Hz .
Sorry for my English....
That looks like the loudest GPU in all existence...I'm not impressed.   <_<
Any thoughts on cheaply fixing that?  :)
Not really...because of the way that GPU is designed... :(
Maybe if you can take the front shroud off and put some 80 or 92mm quiet fans instead of those tiny jet engines :)
Full after market cooler like a gelid icy vision or an accelero 3 would sort you out :-)
Broken fan blades cause vibrarion as the fans are unbalanced
Sim Rig:  Valve Index - Acer XV273KP - 5950x - GTX 2080ti - B550 Master - 32 GB ddr4 @ 3800c14 - DG-85 - HX1200 - 360mm AIO
Quote
Long Live VR. Pancake gaming is dead.
I know about the unbalanced fans, that guy said it's not that bad. An accelero is the last solution tbh... It's just too expensive. Maybe some ugly and weird sealed tubing with a nice big 120 or 140 mm fan at the end... It's not like this card isn't weird already.
oh my god what is that thing
CPU: i7 2600 @ 4.2GHz  COOLING: NZXT Kraken X31 RAM: 4x2GB Corsair XMS3 @ 1600MHz MOBO: Gigabyte Z68-UD3-XP GPU: XFX R9 280X Double Dissipation SSD #1: 120GB OCZ Vertex 2  SSD #2: 240GB Corsair Force 3 HDD #1: 1TB Seagate Barracuda 7200RPM PSU: Silverstone Strider Plus 600W CASE: NZXT H230
CPU: Intel Core 2 Quad Q9550 @ 2.83GHz COOLING: Cooler Master Eclipse RAM: 4x1GB Corsair XMS2 @ 800MHz MOBO: XFX nForce 780i 3-Way SLi GPU: 2x ASUS GTX 560 DirectCU in SLi HDD #1: 1TB Seagate Barracuda 7200RPM PSU: TBA CASE: Antec 300
I expect pics of said monstrosity once it is complete :-)
Those fans do look a little like 1u rack server fans...
Quote
Les noisy fans :
you do realise that your 12v rails on your psu are rated at 20A which is 240w so you really should use that gpu with that psu. also dont replace the heatsink. the fans should never need to go at all
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
Should I? Or should I not?
Power-Consumption.png]
I basically plan to NOT stress the card with furmark. Or I could just hook up an VGA 8pin from Supeflower. another psu fits in the 5.25 driver if i really want it.....
I replaced it after suspecting it of doing damage to HDDs...
I will do some high quality DSLR pics but no fan/cooling mods right now. ( 3 days return policy)
With a knife and lots of patience I could straighten the aluminium fins after taking the shroud off. But the air will still have to leave on the sides... (the vapor chambre gets in it's way).
its the peaks that kill your psu and even in crysis 2 its spiking over 250w
Rig Specs:
The SF 550W has a really stable 12v rail.. I think I'll use the entire PSU just for the card.
EDIT: nope, I won't! read this :
http://www.overclock.net/t/761202/single-rail-vs-multi-rail-explained
here are some (very) low quality pics:
The PCB is about 1 cm too long, it's now in the dvd bay area... Flashed an Asus 280x bios with my custom clocks, voltages and fan profile. It's not that noisy, especially when that one faulty fan is stopped. Very proud of my aquisition,
I am very sory about the dust and picture qualiy, I will do a true build log if anyone is interested.
