Best program for monitoring FPS?
Treyminater
Title says it all. I know of Fraps, but wanted to know what you guys thought was the BEST
I just use fraps, I think MSI has a thing too but I've used it maybe twice.
Hmm, okay. I think ill probably just go with Fraps if no one else gives any good suggestions. Thanks :)
Msi afterburner with riva tuner statistics. There is about 20 or so things you can monitor with an in game overlay, cpu usage per core temps per core, gpu temps,usage,voltage,clock speed, ect. Everything is at your disposal with it. Even the time in between frames.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
Fraps and riva tuner can cause problems with steam overlay, just in case a problem occurs that may be why.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
origin overlay as well
Never had problem with MSi Afterburner OSD. It can show over 9000 stats.
You might want to try overwolf. It's free anyway and it has an fps monitor. I found that it seemed to interfere with one game I have so I uninstalled but i would keep it otherwise. it has other nifty features like in-game Web browser.
