Hey guys. I was wondering if my plan is good for my first build. the link to my amazon wishlist is: http://amzn.com/w/3NAT978DBHVHQ
 I am 15 and can't get a job for another year so I have been saving money for a while and don't want to mess up. I am mostly going to be playing Minecraft and playing Forza, both on max settings. I want to record using fraps and I may run a Minecraft server occasionally. I already have a case but I couldn't find it online. I will have to keep this computer for a while and it will be overclocked with MSI's OC GENIE. Thanks in advance.
Photography is life!
https://linustechtips.com/topic/26776-first-total-build/
budget? and overclock the card with OC Genie? you will be OCing the CPU right? Only gaming? get a 3570k and 8 gigs of ram and get a better gpu.
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
https://linustechtips.com/topic/26776-first-total-build/#findComment-340163
I would go with the GD45 Gaming and a 3570k, then you can step up the gpu to something like a 660-660ti.
Edit: Also, do you really need 16gb of ram? if yes, take this one: http://www.amazon.com/Corsair-Vengeance-Desktop-Memory-CML16GX3M2A1600C10/dp/B007TG8QRW/ref=sr_1_7?ie=UTF8&qid=1371390625&sr=8-7&keywords=16gb+ddr3 because its cheaper and faster.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/26776-first-total-build/#findComment-340189
3770K isn't really for gaming its for redndering and other editing applications. Yes it will give some more frame rates but just about 4-5 thats it.
Get 3570k plus asrock extreme 4 mobo or you are good with gigabyte z77x d3h and put some money towards better GPU such as 7950.
And get 8gb ram g skill ripjaws
PSU looks good too.
https://linustechtips.com/topic/26776-first-total-build/#findComment-340542
Here's what you could do..
Better for gaming: http://pcpartpicker.com/p/17uHF
What's your budget?
https://linustechtips.com/topic/26776-first-total-build/#findComment-345720
Thanks guys. I've decided to lower the ram to 8 gigs and will get a 3570k, so I can get a better gpu. I haven't decided which one yet but i will keep this updated as I go. I almost forgot, My budget is about 1000 USD
Great choice
And if you can post your pictures once you do it.
https://linustechtips.com/topic/26776-first-total-build/#findComment-359004
Alrighty, a few changes: http://pcpartpicker.com/p/18G4g
https://linustechtips.com/topic/26776-first-total-build/#findComment-359187
