I am currently running an H100 with Corsair SP120's to cool my 3770K at 4.7Ghz and am interested in dong a custom water cooling loop.
As such I am have done some research into the matter and watched several videos from Linus and TTL on the matter. This has led me to the conclusion that with some modding of my 600T I can fit a 30mm thick 360 radiator in the roof and if needed a 240 in the front.
Therein lies the question - Would a 360x30mm (Alphacool ST30 360mm) rad be enough if I were to add my GPU (EVGA GTX 670 FTW) to the loop or would I need the 240(Alphacool XT45 240mm) as well?.
https://linustechtips.com/topic/2673-first-time-water-cooling-advice/
A thin rad like that cooling an overclocked 3770k and the GTX would just barely cover it. I would plan on the additional 240 to start as well, just for some extra headroom.... :)
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
A 360 rad would be okayish.
You might want to add a 140/120 rad on the back exhaust for some extra cooling. Or you could go for a thicker 360.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
If you can't go over that 30mm thickness then grab a thick 120 rad just to be on the safe side or a thick 240 in the front to be better off
Corsair 600T White | Gigabyte Z77-UD3H | Intel Core i5-2500k | 8GB Gskill Ares@1600MHz | Gigabyte G1 GTX970 | OCZ ZT 550 | Western Digital Caviar Blue 500GB | Western Digital Caviar Black 1TB | Samsung 840 EVO 250GB (boot) | Full Custom Loop | NZXT HUE
Thanks for the advice, I would not be able to fit anything thicker than 30mm in the top but I could put as thick a 240 as I want in the front so that is probably the way I will go, although looking at the cost of it I think I will do a CPU loop on the 360 just now and get the 240 and GPU block later on.
Thanks for the advice' date=' I would not be able to fit anything thicker than 30mm in the top but I could put as thick a 240 as I want in the front so that is probably the way I will go, although looking at the cost of it I think I will do a CPU loop on the 360 just now and get the 240 and GPU block later on. [/quote']
Buy your Rads seconds hand. You can save a load of cash and there's no real damage you can actually do to a rad.
