Enough Power?
Go to solution Solved by Fate,
Yes you'll be fine, a 750watt PSU is plenty for two 970s.
You're good bro.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/266624-enough-power/#findComment-3622040
Not enough, get an AX1500i.
You're fine with a 750.
I done been through a whole lot. Trial, tribulations, but I know God - Kendrick Lamar
I question your mother's upbringing if you don't like me - Action Bronson
You apocalyptic dingleberry - James 'Captain Slow' May
https://linustechtips.com/topic/266624-enough-power/#findComment-3622048
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
https://linustechtips.com/topic/266624-enough-power/#findComment-3622088
Please don't intentionally post misleading information/troll.
Ummm. I think it's quite obvious that it was supposed to be a joke..   :P
Also, this:
Plus, the three previous comments all said it was fine, and the thread has been answered, so I am pretty sure OP knows the actual answer to his question. Regardless, I'll add an "/s" just in case.  ;)
https://linustechtips.com/topic/266624-enough-power/#findComment-3622115
Ummm. I think it's quite obvious that it's supposed to be a joke..   :P
Also, this:
I knew it was a joke, but many people probably don't.
It's incredibly difficult to sense sarcasm through text.
RIP in pepperonis m8s
https://linustechtips.com/topic/266624-enough-power/#findComment-3622124
No, you'll need two more. And more RAM because you need more RAM for the CPU to work with the GPU as a APU. - Geek Squad employee
Ohh yeah, three AX1500i's that'll probably be enough. Make sure you crossfire them so you can overclock your motherboard. - Apple "Genius"
https://linustechtips.com/topic/266624-enough-power/#findComment-3622139
I was hoping my location would help remedy that  :D
Anyways, I usually write an actual helpful answer afterwards, but you quoted me before I could edit it in.
I agree, sarcasm is WAY too hard to see through the internet.
https://linustechtips.com/topic/266624-enough-power/#findComment-3622151
