The first one.
But take out that expensive HDD and buy something like a WD blue or seagate barracuda instead, they are way cheaper.
https://linustechtips.com/topic/265668-help/#findComment-3610400
The first one.
I3-4150 | Be Quiet! Dark Rock Pro 3 | 8GB KINGSTON FURY RAM | MSI Z97-G43 | HYPERX FURY 120GB SSD SAPPHIRE HD7950 VAPOR-X | Phanteks Enthoo Pro M | EVGA 500W | Corsair SP120's w/ NZXT Fan Hub
Plans: I5-4690K || EVGA GS 650W | KINGSTON FURY 8GB RAM  PCPARTPICKER: https://uk.pcpartpicker.com/
https://linustechtips.com/topic/265668-help/#findComment-3610423
PS. I use my computer for gaming mostly sometimes i do some editing but not much
feel free to criticize other stuff in the build
still i5 would be a better choice
https://linustechtips.com/topic/265668-help/#findComment-3610460
The PSU is overkill, but ready for SLI ;)
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($182.95 @ OutletPC)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard  ($82.98 @ Newegg)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($339.50 @ Newegg)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($34.99 @ Newegg)
Total: $795.89
Generated by PCPartPicker 2014-12-07 13:07 EST-0500
"an obvious supporter of privacy"
https://linustechtips.com/topic/265668-help/#findComment-3610495
Total: $795.89
im using amd cards dude :D
https://linustechtips.com/topic/265668-help/#findComment-3610637
