PCPartPicker part list: http://pcpartpicker.com/p/dPqXFT
Price breakdown by merchant: http://pcpartpicker.com/p/dPqXFT/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (Purchased For $209.00)
CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler  ($59.97 @ Directron)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($89.78 @ OutletPC)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory  ($80.97 @ OutletPC)
Storage: A-Data Premier Pro SP600 256GB 2.5" Solid State Drive  ($79.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($50.49 @ OutletPC)
Video Card: Asus Radeon R9 280 3GB DirectCU II Video Card  ($194.99 @ SuperBiiz)
Case: Corsair SPEC-01 RED ATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($29.99 @ NCIX US)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  ($14.98 @ OutletPC)
Other: Windows 8.1 ($84.00)
Total: $934.15
Generated by PCPartPicker 2014-12-05 16:36 EST-0500
  • Intel i5-4690K | MSI Z97 PC MATE ATX | Corsair Vengeance 8GB (2 x 4GB) | MSI Radeon R9 290 4GB TWIN FROZR | Corsair SPEC-01 RED | Intel 520 Series Cherryville 120GB 2.5" Solid State Drive | EVGA 600B 600W | AOC e2050Swd 60Hz 19.5" Monitor | Cooler Master Nepton 140XL
https://linustechtips.com/topic/264473-first-build-opinions/
Looks good to me, you may want a better case as that will help with the build process and air flow.
<p>CPU: AMD FX-8320 @ 4.0 GHz | GPU: Asus GTX 970 STRIX | RAM: 8GB (2x4GB) Corsair Vengeance LP 1600MHz | Motherboard: Gigabyte GA-970A-UD3P ATX | SSD: Samsung 840 EVO 500GB (Boot Drive) | HDD: 500GB | Case: Corsair SPEC-02 Red |PSU: Corsair 750W | OS: Windows 7 64-Bit | Mouse: Corsair M65 (Black) | Keyboard: Corsair K95 RGB (Black w/ Brown Switches)
https://linustechtips.com/topic/264473-first-build-opinions/#findComment-3597154
All looks good, but I wouldn't bother with water cooling your cpu unless it's at least a 240mm cooler. You may want a Hyper212 EVO instead of the H60, then you can put the money saved towards something else.
https://linustechtips.com/topic/264473-first-build-opinions/#findComment-3597164
Good idea, but if @rhysman2000 wants to watercool, get a Nepton 240M :D
Roses are red, violets are blue, computers are awesome, and so are you!
https://linustechtips.com/topic/264473-first-build-opinions/#findComment-3597180
Might need a bigger psu
PC is Intel Core i5 6400, GIgabyte H170 Gaming 3, Corsair Vengeance LPX 2x4GB 2400Mhz ,Sandisk Ultra Plus 128GB, WD Blue 1TB, NZXT S340, ASUS Geforce GTX 960. Fractal Design Tesla R2 650W. http://au.pcpartpicker.com/p/793XNG. Graphics card choices don't always have to be dictated on performance. If you want the game stream and power consumption of the GTX 970 get that. If you want raw performance of the R9 390 get that. In the end we are all gamers, so what if your buddy gets an extra 5 fps?
https://linustechtips.com/topic/264473-first-build-opinions/#findComment-3597528
