Power button issues.
Go to solution Solved by LogicalDrm,
Alright, so my Corsair 450D has a two pin power button connector and my mobo has a 3 pin, what do m9?
If you haven't solved this yet, I think you are mixing power and reset button Grounds. The power button ground is next to it, not opposite to it.
check that it is a power button header on the motherboard, not a fan header.
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/263397-power-button-issues/#findComment-3582713
What motherboard do you have? I seriously doubt that you have a 3 pin conncetor on the board for that.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/263397-power-button-issues/#findComment-3582716
Also the case has 3 pin fans and it has 4 pin connectors, fuck. what do
The 3 pin fans work on 4 pin connectors. They are exactly the same. It's just that the 4 pin has an extra pin for PWM control.
https://linustechtips.com/topic/263397-power-button-issues/#findComment-3582796
what side of the connector should I favor?
They only fit one way. Follow the indent on the plug with the block on the fan header.
Please do not plug them in while the system is running. You will fry the connector.
https://linustechtips.com/topic/263397-power-button-issues/#findComment-3582817
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/263397-power-button-issues/#findComment-3585594
Read your manual carefully, take your time and don't rush anything.
CPU: i7 4790k OC'd @ 4.6 ghz COOLER: Corsair H105 (SP 120mm Quiet Edition Fans) MOBO: ASRock Z97 Extreme 6 RAM: Kingston Hyper Fury 16GB (2x8) 1866mhz
SSD: Samsung 840 EVO 250GB HDD: WD Blue 1TB GPU: EVGA GTX 970 FTW 4GB PSU: EVGA Supernova G2 750w 80+ Gold Fully Modular CASE: Fractal Arc Midi R2
OPTICAL DRIVE: Samsung DVD Burner OS: Win 7 64bit   Please do some research of your own before asking questions. Google and Youtube are your friend.
https://linustechtips.com/topic/263397-power-button-issues/#findComment-3586755
Yeah, I figured it out in like 3 minutes, these AsRock boards have terrible instructions, Im used to a EZ mode ASUS. :L
PEWDIEPIE DONT CROSS THAT BRIDGE
https://linustechtips.com/topic/263397-power-button-issues/#findComment-3586908
