Best 27 inch 1440p ips monitor
doestilvoort
The one you can afford.
well thats an easy answer
exept i dont know wich one is the best
It's pretty hard to say which is the "best" as none of us here have a bunch of models to compare.
What is your budget?
between 300-500 euro
ASUS PB278Q best one!
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
I would agree for the price you cant go wrong,
after that you would step up to a HP or a eizo
Its all about those volumetric clouds
and will my asus r9 280oc 3gb ran it good? like stable fps above 50 in games?
Probably not on ultra in every game, my 780ti struggled to do that
Also check out the AOC Q2770PQU, same panel as the Asus but is sometimes much cheaper to buy
Another option is the Dell u2713hm, or the AOC mentioned by ShadowCaptain above.
Whichever is cheaper.
May be with Medium or High in some titles.
Remember, there is a newer model than the ASUS PB278Q; the ASUS PB278QR. About the same monitor but it has the non PWM backlight which is easier on the eyes. And the price is also lower(in my country).
This model is only available in certain regions though, just a heads up.
