Geforce 256 fan has siezed
Go to solution Solved by D2ultima,
You could try taking the fan apart and using some WD40 on it and trying to get it to spin... but seeing as how I have no actual idea what a GeForce 256 is, I'm going to assume it's immensely old and probably not worth trying to get an actual replacement... they should be hard to find O_O.
I've recently decided to clean and rebuild my old computer, and I've discovered that the fan on the graphics card has siezed. The motor still works as it twitches when the computer starts, but since it overheats I'm having to rely on the stealth 3 that it replaced. Is there a way fix it or should I just replace the whole fan/heatsink unit.
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
https://linustechtips.com/topic/260751-geforce-256-fan-has-siezed/
I'm pretty sure you could rig something up or find a replacement on ebay
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
I have finally moved to a desktop. Also my guides are outdated as hell.
THE INFORMATION GUIDES: SLI INFORMATION || vRAM INFORMATION || MOBILE i7 CPU INFORMATION || Maybe more someday
Remove the fan, then remove the sticker on the back of the fan(and any dust cap), then use spray lube like Tri flow to lubricate the bearing(or WD-40 if you are that kind of person, lol). Spin the fan with your hand to work in the lubricant and add more if necessary(a little goes a long way). Then reverse your disassembly process.
Remove the fan, then remove the sticker on the back of the fan(and any dust cap), then use spray lube like Tri flow to lubricate the bearing(or WD-40 if you are that kind of person, lol). Spin the fan with your hand to work in the lubricant and add more if necessary(a little goes a long way). Then reverse your disassemble process.
WD40 FUH LYFE HOMIE *drives by in grove street colours with a Tec-9*
Thanks for the quick reply, I used the WD40 as suggested and its working fine now.
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
