Hey guys, I am replacing my Krakens finally and I need a mic to go along with my ATH-AD500xs that I picked up on sale for 80 bucks. I need a good stand alone microphone for around 50 bucks. I know of the Blue Snowball, but is there anything better than it that you would recommend? My preferred color is black or green but that doesn't really matter. Thanks for your responses! bai now
EDIT: One of the things I was trying to avoid with a stand alone mic was leakage to the mic from my headphones like what I get with my Krakens, so I won't really be able to use a modmic or something that is to close to my head.
wow, thats a lot of bees!
https://linustechtips.com/topic/260576-best-mic-for-50/
I use a Zalman clip on mic, 7$.
https://linustechtips.com/topic/260576-best-mic-for-50/#findComment-3551691
The blue snowball is good, there is also the samson meteor mic and the modmic 4.0.
https://linustechtips.com/topic/260576-best-mic-for-50/#findComment-3551770
modmic 4.0. It is a really great mic
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/260576-best-mic-for-50/#findComment-3552011
CAD U37 occasionally goes on sale within budget.
Don't even worry about that. It isn't an issue anyone has. The ModMic is a perfectly good option.
https://linustechtips.com/topic/260576-best-mic-for-50/#findComment-3552020
