American parts in a UK pc?
Hi guys,
Bit of a noob, never built a pc before.
I was looking at the UK and US versions of pcpartpicker, and I realised that the price difference between the two sites for the rig I want to build is over £200 (yes I did convert £ to $ and vice versa)
This got me thinking, if it's so much cheaper to buy US parts, why don't I do exactly that? (I know that postage could be expensive, so this only applies to smaller parts)
So my question is, other than the PSU (due to different sockets), are most US components compatible with the mains power in the UK? If so is there anything I need to watch out for?
Thanks in advance
Import duty and VAT must be paid when it arrives in the UK.
Add on around 40% from the USD to GBP conversion price.
The power supply is the only part that is potentialy not going to work. Make sure it has 240v listed as its input. Most have a red sliding switch, others will not require any input from the user. I doubt any from a good brand will give you any problems.
