If I get another 290, I would have to put it in the top PCIe slot in my motherboard. So the fans would be right up against the back of the other card. If I got one of the better coolers (like the sapphire tri-x/vapor x), would it stay cool and be quiet even though the fans don't really have any room?
XEON E3 1231v3 | GA-Z97MX GAMING 5 | XFX R9 290 | 16GB RAM | CRUCIAL MX100 256GB | WD BLUE 1TB | EVGA SUPERNOVA 850W | CORSAIR 350D
https://linustechtips.com/topic/258915-r9-290-crossfire-cooling/
You might want to get a ref card if they are going to be sandwiched together, as the top card can pull air from the front of the card.
REMEMBER TO QUOTE SO I GET A NOTIFCATION! Add me on Steam: http://steamcommunity.com/id/Shroomster/ Review(s) more to come
https://linustechtips.com/topic/258915-r9-290-crossfire-cooling/#findComment-3535934
Hows the airflow in the case?
CPU: Intel i7 4770k w/Noctua NH-D15, Motherboard: Gigabyte Z97 Ultra Durable, RAM: Patriot 8Gb 1600Mhz (2x4Gb), GPU: MSI R9 390x Gaming,
SSD: Samsung 840 EVO 1Tb, HDD: Caviar Black 1Tb, Seagate 4Tb Hybrid, Case: Fractal Design Define R4, PSU: Antec Earthwatts 750w
Phone: LG G2 32Gb Black (Verizon) Laptop: Fujitsu Lifebook E754 w/ 1TB Samsung 840 Evo SSD Vehicle: 2012 Nissan Xterra named Rocky
https://linustechtips.com/topic/258915-r9-290-crossfire-cooling/#findComment-3535971
Are you saying that a reference card would be better than something like a sapphire tri-x in that situation?
https://linustechtips.com/topic/258915-r9-290-crossfire-cooling/#findComment-3536205
I have a corsair 350d, airflow could be better. There's just the fans that came with the case(big one in the front, a smaller one in the back... Not really sure about exact sizes..). I could add more fans though if it was necessary
https://linustechtips.com/topic/258915-r9-290-crossfire-cooling/#findComment-3536221
If they're going to be sandwiched together, yes the reference cooler will be better for that.
https://linustechtips.com/topic/258915-r9-290-crossfire-cooling/#findComment-3538236
Two open coolers would generally be better, but they don't like being squished up against eachother, so probably not. You really want some gap between them.
Sandwiched csrds right against eachother is a no go... My msi twin frozor overheated and throttled to 500 mhz within 2 mins
Swapping to a refernce blower required 65% fan speed to avoid throttling. Very loud...
With one pci slot between them it was much better but the bridgeless xdma over chipset based pcie3.0 x 4 caused micro stutter
Sim Rig:  Valve Index - Acer XV273KP - 5950x - GTX 2080ti - B550 Master - 32 GB ddr4 @ 3800c14 - DG-85 - HX1200 - 360mm AIO
Quote
Long Live VR. Pancake gaming is dead.
https://linustechtips.com/topic/258915-r9-290-crossfire-cooling/#findComment-3539831
See above post
Quote
https://linustechtips.com/topic/258915-r9-290-crossfire-cooling/#findComment-3539833
kraken g10 is another option. Gelid sell a VRM heatsink for the 290 if yours don't have. I have both my 290's with G10's and H50's on them, and temps are hilariously low.
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
https://linustechtips.com/topic/258915-r9-290-crossfire-cooling/#findComment-3539892
The G10 is not a 2 slot cooler it's 2 1/2 slot
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/258915-r9-290-crossfire-cooling/#findComment-3539923
Is there space for that when the cards are sandwiched together though?
I have about an inch of wiggle room between the two cards, where the tubes come out from the pump. half inch at the vrm fan.
https://linustechtips.com/topic/258915-r9-290-crossfire-cooling/#findComment-3539962
Very interesting, I had always assumed the space would be too little.
I could take a picture of mine, but it looks almost identical to this. as long as there are two slots between the cards. I just looked at an image of your motherboard, and now I know what you mean about the spacing being tight for pci-e, and looking at you case I guess there wouldn't be enough clearance anyway.
https://linustechtips.com/topic/258915-r9-290-crossfire-cooling/#findComment-3540001
It's not me with the mATX case, I'll have a gap between my cards when I get the second one :P
https://linustechtips.com/topic/258915-r9-290-crossfire-cooling/#findComment-3540031
haha, too early in the morning for me then.  :lol:  ^_^
https://linustechtips.com/topic/258915-r9-290-crossfire-cooling/#findComment-3540079
I was planning on getting a g10 for my xfx double dissipation 290 that I have now. It gets hot and loud... But I thought I would have to put it in the bottom slot because it is a 2 and a half slot cooler. I don't think I can get a second g10 for the top card. I have a gigabyte z97mx gaming 5 motherboard.
Do you have an atx motherboard though? I have a micro atx board and I don't think 2 g10s will fit
https://linustechtips.com/topic/258915-r9-290-crossfire-cooling/#findComment-3540888
The 350d has 5 slots, so each 2.5+2.5=5, but it might be a little tight
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
https://linustechtips.com/topic/258915-r9-290-crossfire-cooling/#findComment-3540944
I think the problem is my motherboard though. Do you know if two g10s or corsair hg10s would fit on the gigabyte z97mx gaming 5
https://linustechtips.com/topic/258915-r9-290-crossfire-cooling/#findComment-3541316
yeah atx. there is a pci-e x1 slot and a regular pci slot between the two pci-e x16 slots on mine that I use, probably why I have so much room.
https://linustechtips.com/topic/258915-r9-290-crossfire-cooling/#findComment-3541394
As you can see there is a PCI 1 in-between the two x16's so it should work
https://linustechtips.com/topic/258915-r9-290-crossfire-cooling/#findComment-3541432
198032.jpgOh okay. Unfortunately, I only have one slot in between where the gpus would go. I should've gotten an atx board with the define r4..the only reason I went with micro atx was because it was like $20 cheaper at the time. I didn't forsee this problem
https://linustechtips.com/topic/258915-r9-290-crossfire-cooling/#findComment-3541479
But the g10 is 2.5 slots right? So wouldn't it cover up the pci1 and the PCIe x8 too?
https://linustechtips.com/topic/258915-r9-290-crossfire-cooling/#findComment-3541492
