When will 1080p be outdate?
Is it worth buying a 1080p monitor anymore or will it be phased out soon so it's better just investing in at least a 1440p?
It's gonna be mainstream for a while. What are your specs?
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
1080p is still a good standard. Most people wouldn't need more.
Intel 4790k | Asus Z97 Maximus VII Impact | Corsair Vengeance Pro Series 16 GB 1866Mhz | Asus Strix GTX 980 | CoolerMaster G550 |Samsung Evo 250GB | Synology DS215j (NAS) | Logitech G502 |
Seeing as most, if not all, programs still support down to 800x600 or at least 1024x(whatever that was), i really dont believe 1080p will be "phased out" any time soon.
CPU i7-9700K @ 5 GHz Motherboard ASUS ROG Strix Z390-F RAM Corsair Vengeance 32 GB (4x8) 3000 MHz GPU ASUS RTX 2080 ROG Strix OC x2 SLI Case Corsair Graphite 780T Storage 256 GB Samsung 860 EVO, 6 TB Seagate Barracuda PSU Corsair HX1200i, 1200W Display(s) ASUS PG279Q (1440p 165 Hz), ASUS VG248QE (1080p 144 Hz) Cooling ASUS ROG Ryujin 360 radiator Keyboard Logitech G710+ Mouse Logitech G502 Sound Logitech G35 Operating System Windows 10
I woad go wight 1080p monitor evain awrthing is starting to move to 4k but it will still be  on market fore at least 5 years since new super hi rez(6k if comes out)woad be 2000 dolars probly and awrthing will go down in price so it will be a bit cheaper i woad go wiight 1080p and you shoad go since it woad be a standard fore a long time
I would say for quite some time but you never know what the next lithography of gpu's have in store. The only indicator is how powerful graphics cards get. If buying a high end gpu means 4k 60fps easy without sli then that is when it will become a standard. But that's several gens away at least.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
probably another 10-20 years.
1080p will continue to be mainstream until GPU hardware has advanced so much that 1080p max settings with even some AA to fit as well is possible on one or both of the following:
  • $60 and under home theatre GPUs
  • Integrated graphics chips in CPUs
Ofcourse, the higher resolution monitors will be available and in excess before that point is met. that's what happened to 720p, almost anything can run 720p and max it out if it's been made within the last 2 years, 720p with minimum graphic settings if its been made within the last 4 years
System: Intel Core i3 3240 @ 3.4GHz, EVGA GTX 960 SSC 2GB ACX 2.0, 8GB 1600MHz DDR3 Kingston HyperX RAM, ASRock B75M-DGS R2.0 Motherboard, Corsair CX430 W Power Supply
