Help! Noob in trouble!
Go to solution Solved by Alun,
I have sorted everything out now with my friends in school today. Thanks for the help :)
Hi,
I am new to pc building and I just want a few suggestions for my next few pc parts at the moment I have:
GPU: EVGA GeForce GTX 970 SC ACX 2.0 4096MB GDDR5
Case: Aerocool Strike-X GT Red Devil
Here is what I plan to get:
MotherBoard Combo: http://www.overclockers.co.uk/showproduct.php?prodid=BU-006-MS
And I need the PSU and HDD do you have any suggestions? I know this seems like a stupid question but I just want to be sure I get something good. Thank you :)
https://linustechtips.com/topic/256736-help-noob-in-trouble/
You dont want a GPU? That is a good bundle at a good price.
I suggest a Seasonic G550 PSU my self and maybe an R9 280X GPU or R9 290 if they are cheap in the UK otherwise a GTX 970 would be best.
Dont forget a CPU cooler so you can OC! Hyper 212 will get er done.
Intel Inside. Overweight guy in his 30's outside.
https://linustechtips.com/topic/256736-help-noob-in-trouble/#findComment-3512733
Dont skimp out on a PSU. It is the most stupid thing you can do.
http://uk.pcpartpicker.com/part/corsair-power-supply-cs650m
http://uk.pcpartpicker.com/part/evga-power-supply-120pg0650gr
These are good PSU's in your price range one semi and one fully modular. There also other good ones let see if someone can come with better priced ones.
https://linustechtips.com/topic/256736-help-noob-in-trouble/#findComment-3515554
