Radiator Position, Air Pressure.
Having more intake fans than exhaust fans will keep the air pressure positive, but only a bit of positive air pressure is needed to keep dust from coming in.
You are trying to keep dust from coming in through cracks, not trying to push air much air as possible out of those cracks.
By using exhaust fans, they assist the intake fans in moving more air through the case to keep temperatures lower.
Having a lot of positive air pressure will not help keep dust out any more than having a little positive air pressure.
Having a lot of positive air pressure will also make your temps higher, which you dont want.
In your case, I would put the radiator as exhaust on the top, then have intake fans all over the front.
Since the exhaust fans on the radiator will have more air restriction, the front fans will keep positive air pressure in your case even if the number of front and top fans are the same.
