I'm rather displeased with the temps on my 7950, and I was wondering if there was some kind of AIO solution that I can throw on it. It's the XFX Double Dissipation deal, and as far as I can remember, it is a non-reference PCB. As long as it stays quiet and the temps stay below 70C, I'd be happy.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/255673-aio-watercooling-solution-for-this/
^The G10 looks amazing go with that
If I've said something wrong, please correct me
My Builds:
Peripherals:
Keyboard: Roccat TKL Pro Cherry MX blue, Mouse: Roccat Kone XTD, Headset: Currently apple earbuds, planning to upgrade to hyperx cloud or hyperx cloud 2
Really Old Desktop
 Processor: Intel Core i7 920, Motherboard: Gigabyte GA-FX58-DS4, RAM: 9GB Corsair XM3 (3*3GB in triple channel) 600 or 800mhz, Graphics Card: Asus 8400GS passive, Asus GT630 4GB if i can get it working, Case: Cheapo Throwout case with most of the standoffs missing, HDD: Some old 80GB hard drive, PSU: Thermaltake Toughpower 550w, Monitor: 32" Kogan TV, OS: Fedora 13
 Laptop Which I Use For Everything:
Processor: Intel Core i5 3337U, RAM: 8GB (2*4GB) 1600MHZ, Graphics Card: Nvidia 710m HDD/SSD: WD Black2 Dual Drive, OS: Windows 8.1
 40 GB/s Network Tester
Processor: Some really good Intel Core i3, Motherboard: Gigabyte GA-H67N-USB3-B3, Ram: Corsair Value Select 4GB (2*2GB) 1600MHZ, Graphics Card: Integrated, Case: Some 1U rackmount mini-itx case with no front bays, HDD: Seagate Momentus 5400, 250GB 2.5" 5400RPM, PSU: Enchance 250W 80+ Bronze 1U power supply, CPU cooler: Cooljag double ball bearing 1U cooler (70DB! 70DB!), NIC: Mellanox 40Gb/s QSFP+ PCIe 3.0 8x NIC, Monitor: any ones lying around, or 32" Kogan TV, OS: CentOS 6.2 (I Think)
Planned 100Gb/s Newtork Tester
Processor: Intel Core i7 4790k, Motherboard: Asus Maximus VII Impact, Ram: Kingston or G.Skill 8GB 2400MHZ Low Profile, Graphics Card: Integrated, Case: 1U Rackmount ITX case, HDD: Samsung 850 EVO 120GB, PSU: Enchance 250W 80+ Bronze 1U power supply, CPU cooler: Cooljag double ball bearing 1U cooler (70DB! 70DB!), NIC: Mellanox 100Gb/s PCIe 3.0 16x NIC, Monitor: Any lying around or 32" Kogan TV, OS: Fedora 22 or CentOS
Kraken G10 and corsair hydro series h55.
H110 or H105 ;)
@TheProfosist largest radiator I can have at the moment is 120mm. ;)
Main rig on profile
VAULT - File Server
OptiPlex 7040M
@TheProfosist why.. that is so hilariously pointless.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
@Aniallation It is? SWEET!!!
Also, this quote-not-working bullshit is starting to piss me off.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
Reference or non  It wouldn't matter anyway, as long as the mounting holes are the same distance apart, etc and I didn't think they would change that but I could be wrong, definetly something to look into. The g10 only attaches as a regular AIO mounts to a cpu/mobo. As long as they didn't move the power delivery system to some obscure place. 120mm AIO is fine but the fan should be ramped clearly up on it to compensate, that said You can probably get 70C temps without having the fan too loud.  But the 7950 when the g10 released was n't stated as compatible but since then they have said it should work but you may need a shim.
** Some variations in AMD die height may require the use of a shim.
I had a XFX CORE edition 7950, so single fan, open cooler in a terrible air flow case and that thing was ungodly loud.... Even with the side panel off I thought it might explode one day until,,,, tea made its way onto the PCB....
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
@Aniallation Mine is the dual-DVI version. :(
Main rig on profile
VAULT - File Server
OptiPlex 7040M
@Imabigmac
Yes that is true, the G10 isn't a full-cover block, so it shouldn't be a big deal of reference or non reference. I can see where the two XFX cards differ by looking at the PCBs and can tell why a reference full-cover block would not fit, but I see no reason why a G10 wouldn't.
"Rawr XD"
You sir answered your own question.
@Imabigmac
How certain are you that it would fit?
Main rig on profile
VAULT - File Server
OptiPlex 7040M
