Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard  ($88.99 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($119.98 @ OutletPC)
Video Card: Sapphire Radeon R9 280X 3GB Dual-X Video Card  ($241.99 @ SuperBiiz)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($64.99 @ Micro Center)
Total: $1020.88
What do you think about this pc build? Any suggestions? Max budget 1100$. I`m from Latvia.
https://linustechtips.com/topic/255172-first-build-plan/
If this is a gaming rig then drop 8GB of RAM and get a GTX 970. You can always upgrade your RAM later.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/255172-first-build-plan/#findComment-3494712
would really suggest a 970, it's a really good upgrade.
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/255172-first-build-plan/#findComment-3494742
Thanks! :)
No... Look at his profile picture and his title...
Try to get a 290 in there at least..
PCPartPicker part list: http://pcpartpicker.com/p/6RXKkL
Price breakdown by merchant: http://pcpartpicker.com/p/6RXKkL/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($208.99 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.98 @ OutletPC)
Memory: G.Skill Sniper Gaming Series 16GB (2 x 8GB) DDR3-1600 Memory  ($121.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($53.89 @ Directron)
Video Card: Gigabyte Radeon R9 290 4GB WINDFORCE Video Card  ($264.99 @ Newegg)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($89.99 @ NCIX US)
Total: $1043.79
Generated by PCPartPicker 2014-11-22 05:42 EST-0500
#SAMSUNG  "provided us 4 1tb ssds so we could run the whole site off solid state." - LinusTech
#GALAXY
#ATIV
https://linustechtips.com/topic/255172-first-build-plan/#findComment-3494752
Total: $1043.79
This guy always breaks promises.
https://linustechtips.com/topic/255172-first-build-plan/#findComment-3494791
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($134.99 @ Micro Center)
Storage: Crucial MX100 128GB 2.5" Solid State Drive  ($69.93 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($53.59 @ Directron)
Video Card: EVGA GeForce GTX 970 4GB ACX 2.0 Video Card  ($329.99 @ NCIX US)
Case: Cooler Master N400 ATX Mid Tower Case  ($54.99 @ Micro Center)
Total: $1029.44
i5 4690k, a good gaming mobo for overclocking, mlc 128gb ssd, gtx 970 , quality seasonic psu, nwe gtx 970, case with 2 case fans
if you want 250gb ssd instead i would suggest the MX250gb(109$) version and get this mobo instead : Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard  ($88.99 @ Newegg)
https://linustechtips.com/topic/255172-first-build-plan/#findComment-3494816
