My parents ran over my old razer hammerhead pro earbuds over with a vacuum (no idea how it happened). Anyway they said they will buy me a new pair or ones of equivalent price so 80$ is my budget. Do you guys recommend any 80$ or lees earbuds that look good and sound decent. Ps i am not an audiophile so i don't need super amazing headphones but looks is quite important to me. Thx in advance
i5 4670k / Be Quiet Dark Rock Pro 3 / Asus Maximus vi hero lga 1150 mobo / Sapphire tri-x r9 290 OC edition / corsair vengeance pro red 4 x 4 gb 2133mhz cas 9 ram kit / nzxt phantom 530 black / 120gb samsung 840 evo ssd / 240 gb ocz arc 100 ssd / 2x 1tb WD Blue / Cooler Master v850 modular psu / corsair k70 rgb cherry mx Brown / mad catz rat 5 laser mouse / windows 10
https://linustechtips.com/topic/254949-80-or-less-in-ears/
#SAMSUNG  "provided us 4 1tb ssds so we could run the whole site off solid state." - LinusTech
#GALAXY
#ATIV
https://linustechtips.com/topic/254949-80-or-less-in-ears/#findComment-3492119
srry should ave put this in the original but i am sort of a bass head. recommend anything else bass heavy?
https://linustechtips.com/topic/254949-80-or-less-in-ears/#findComment-3492143
i mean, theyre not that bad, if there were i wouldnt have them in my ears rn :P
https://linustechtips.com/topic/254949-80-or-less-in-ears/#findComment-3492160
10 more dollars and get the shure se 215
In Canada on sale i could only find them for 120$ on sale. Do you recommend anything cheaper.
https://linustechtips.com/topic/254949-80-or-less-in-ears/#findComment-3496989
Sennheiser mommentum inears and ATH IM70 has some great reviews and they are both under 100 dollars,i am not familiar with Canadian dollars though...also check out Klipsch s4 in ear,i am currently using one and it sounds very good at 60 dollars it is worth the money,but if you can test them before you buy some people have problem with the klipsch in ears not fitting properly.
https://linustechtips.com/topic/254949-80-or-less-in-ears/#findComment-3500708
Do u have any thoughts on the Audio Technica ATH-CHX7iS. I really like the look of them and as i said i am not an audiophile so sound doesn't concern me very much, but they are still from a well known brand
https://linustechtips.com/topic/254949-80-or-less-in-ears/#findComment-3501211
