Hi
I am looking for a mid tower case which is preferably silent or noise dampened by design, side window is not necessary.
I have 2 main cases that I have found at the moment;
Bitfenix Ghost , Nanmoxia Deep silence 1
Please give me feedback on these cases or give me some other suggestions :D
NB// I live in New Zealand so my country may not stock some suggestions
https://linustechtips.com/topic/253503-help-me-pick-a-silent-case/
NZXT H440
Fractal Define R4
Zalman R1
I dont know anything about those 2 cases you posted. Friend got Zalman R1 it is awesome case for its price. I got Define R4 and I am really happy with it and a lot of people here seems to recommend H440.
NZXT H440
Fractal Define R4
Zalman R1
How is the build quality of the Zalman R1, it seems to be at a pretty killer price
Maybe have a look at the new Be quiet! Silent Base 800. It seems to be both quiet and cooling well..
BTW: it's not on sale yet i think
Desktop: Intel i9-10850K (R9 3900X died 😢 )| MSI Z490 Tomahawk | RTX 2080 (borrowed from work) - MSI GTX 1080 | 64GB 3600MHz CL16 memory | Corsair H100i (NF-F12 fans) | Samsung 970 EVO 512GB | Intel 665p 2TB | Samsung 830 256GB| 3TB HDD | Corsair 450D | Corsair RM550x | MG279Q
Laptop: Surface Pro 7 (i5, 16GB RAM, 256GB SSD)
Console: PlayStation 4 Pro
Your PC can only be as silent as the components inside. Having good fans and controlling them adequateley is far more important for silence.
History lesson aside, i can recommend the Fractal Design Define R4. The Nanoxia that you found is very very similar, in fact they are produced in the same manufacturing hall. Both are pretty good.
who cares...
Im thinking towards the Nanoxia deep silence 1, it is pretty much exactly the same as the Fractal R4 but has a better door design in my opinion :)
