Need some help with Firebase. Its all in Node.js and HTML.
Solved by neystro,
Nope still broken.
This is the page I am using it on fyi: https://deltadoor.herokuapp.com/products.html
from what I can see in your source code from your website:
line 138 of products.html: change for <div ng-repeat="product in products" class="col-md-3 col-sm-6 highlight">
line 230 of products.html : I get a 404(not found) <script src="js/app.js"></script> will work
you can give me your github repo if you want to.
