so recently I water cooled my r9 290x, I did a bit of overclocking. 1100mhz is the highest I can go before i start to artifacting I think its called, if i go higher than 1170 any game i play may as well be called shroom simulator! I forgot to ask is this normal good or did I get an unlucky GPU?
PCPP http://pcpartpicker.com/p/Vg96f7 CPU: Intel i7 4790K MoBo: Gigabyte Z97X S.O.C Ram: G.Skill 2x 8gb GPU: 2x AMD R9 290x in CrossFire SoundCard: Creative Sound Blaster z Case: NZXT H440 RED/BLK Storage: 2x Intel 520s 120gb Raid 0 + 2tb Seagate 7200 PSU: EVGA 1000W G2 Fully Modular Display: Samsung UHD 4K 28'' KeyBoard: Corsair K65 RGB Mouse: Cyborg R.A.T 7 Sound: Logitech z506 OS: Windows 10 TP
https://linustechtips.com/topic/252528-overclocking-my-290x-problems/
oh well, sounds like my 780 can't do a lot with it i tried but it always crashes if i hit like +80/+50 mhz on the core
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
Probably a bad chip; just go safe and keep it under or equal to 1100.
My Rig: AMD Ryzen 5800x3D | Scythe Fuma 2 | RX6600XT Red Devil | B550M Steel Legend | Fury Renegade 32GB 3600MTs | 980 Pro Gen4 - RAID0 - Kingston A400 480GB x2 RAID1 - Seagate Barracuda 1TB x2 | Fractal Design Integra M 650W | InWin 103 | Mic. - SM57 | Headphones - Sony MDR-1A | Keyboard - Roccat Vulcan 100 AIMO | Mouse - Steelseries Rival 310 | Monitor - Dell S3422DWG
Every GPU is different, and it seems like yours is not one of the best.
Just leave it where its stable and be happy you could overclock at all :)
Thanks for your help. I know how to fix it I'll buy another then I won't have to overclock them
