Fractal Case Question
Go to solution Solved by Guest,
Yes they are.
I am trying to find a new windowed side panel for my black Fractal Design R4, but all I can find is a Fractal Arc Midi. Would these two panels be interchangeable? Thanks!
Arc Midi a panel link: http://www.cometsupply.com/mp/FRACTAL+DESIGN/pm/FRCFDACWNDDEF4ARCBL/r/ga/?gclid=CI2lsvXT_8ECFYIRMwodmEkA-w
i5 4670k, GTX 970, 12GB 1600, 120GB SSD, 240GB SDD, 1TB HDD, CM Storm Quickfire TK, G502, VG248QE, ATH M40x, Fractal R4
i5 4278U, Intel Iris Graphics, 8GB 1600, 128GB SSD, 2560x1600 IPS display, Mid-2014 Model
All the parts are here, just need to get customized cords to connect the motherboard to the front panel.
https://linustechtips.com/topic/251831-fractal-case-question/
Yes it will work. The R4 and Midi are based off the same chassis.
http://linustechtips.com/main/topic/101435-arc-midi-r2-define-r4-window-compatibility/
"Rawr XD"
https://linustechtips.com/topic/251831-fractal-case-question/#findComment-3451486
Yep
Yes they are.
Thank you guys!
https://linustechtips.com/topic/251831-fractal-case-question/#findComment-3451488
