Sooo, whats this and how can I fix it. New to the whole virtual machine thing. Thanks
post-11646-0-77971900-1416107709_thumb.p
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/251532-hyper-v-problem/
Post has been fixed (Pictures added now)
| F@H STATS |
https://linustechtips.com/topic/251532-hyper-v-problem/#findComment-3447523
I'd make a start by using Virtualbox
Second point is make sure boot priority is set so that the Virtual Disk Image file is first in order.
Nothing much to say, Enable it in the BIOS and away you go... Feel free to install VM's at your will.
----edit----
That looks like your VM is set to PXE boot (boot from network) this may be a setting from inside your Hypervisor.
If I set my VM to run on a separate HDD does my ISO have to be on the separate HDD?
| F@H STATS |
https://linustechtips.com/topic/251532-hyper-v-problem/#findComment-3447563
I havent used Hyper-V much I tend to use Oracle virtual box, But id imagine your ISO can be mounted from any point.
Heres the settings
| F@H STATS |
https://linustechtips.com/topic/251532-hyper-v-problem/#findComment-3447589
Yeah, I like how this is built in though. Also if I ever get into networking they're going to use Hyper-V not Virtualbox
Can't I just install the OS later after the VM is created?
| F@H STATS |
https://linustechtips.com/topic/251532-hyper-v-problem/#findComment-3447671
Tried extracting the setup file with WinRAR and it said it was corrupted. I'll download it again and go from there.
| F@H STATS |
https://linustechtips.com/topic/251532-hyper-v-problem/#findComment-3447707
They don't, most company's use some form of stripped back level 1 hypervisor with CLI only. But yeah that looks the same as Vbox, just select the iso and you are good to go.
Quack 🦆
https://linustechtips.com/topic/251532-hyper-v-problem/#findComment-3451029
I like how people suggests to install Virtual Box an inferior VM for Windows OS.
Can you post all the configurations of Hyper-V, including the network card you made.
I believe you didn't create your network adapter correctly, where you created a legacy one.
https://linustechtips.com/topic/251532-hyper-v-problem/#findComment-3458512
It looks like the VM is trying to boot from the network instead of disc image (.iso) or virtual hard drive. Just make sure that virtual disc drive is the first in the boot order and that the .iso is mounted to it, which it looks like you have from the 2nd screenshot you posted.
I can't recall but when its booting you might have to press a key to make sure it boots from virtual disc. Is it still giving you problems despite the settings being right?
CPU: i7 4790K  RAM: 32 GB 2400 MHz  Motherboard: Asus Z-97 Pro  GPU: GTX 770  SSD: 256 GB Samsung 850 Pro  OS: Windows 8.1 64-bit
https://linustechtips.com/topic/251532-hyper-v-problem/#findComment-3459572
Based on the name of your vhdx and the iso I assume you're going to be running Windows 7? You've selected Generation 2 when creating your VM (you have SCSI controllers instead of IDE controllers and there's secure boot in your firmware options.) Gen 2 only works for Windows 8 and Windows Server 2012. You need to delete the VM, create a new one using Generation 1, and you'll be good to go.
Even if you were running a Gen 2 supported OS getting it to boot from an ISO the first time is a bit of a pain and I usually disable secure boot and remove PXE all together.
https://linustechtips.com/topic/251532-hyper-v-problem/#findComment-3459625
Well the OP is keeping details secret. So we help so much, and only playing guess work. We all assume that the OP READ what he or she was doing, and not randomly picking options.
I deleted that line but my point was more towards the "switch to VirtualBox" people. Hyper-V is hardly my favourite virtualization product but I can tell you it's superior to VirtualBox. It's a bit like someone saying "hey guys, I can't get this action to work in Photoshop" and having a bunch of "you should use GIMP" replies... It just doesn't follow.
https://linustechtips.com/topic/251532-hyper-v-problem/#findComment-3459827
I mostly use Gen 1 for better compatibility and less hassle. Also I want to use a physical DVD drive. Gen 2 doesn't support that.
I use Gen 2 for Windows Server 2012/R2 VMs and so far haven't had any issues save for the earlier mentioned pain of getting it to boot from an ISO for the first time. My desk is in Canada and the farms I work in are spread across the US and the rest of the world, I'm not going to be popping DVDs into drives any time soon. For that reason the lack of physical disc drive support isn't a real concern to me; All of our Hyper-V clusters are built with or with access to an ISO share.
There have been a few instances where I've had to build out Windows Server 2012 VMs on Gen 1 but the specifics of why escape me at the moment...
https://linustechtips.com/topic/251532-hyper-v-problem/#findComment-3463680
Precisely! It's counter productive to offer that as advice, it's basically the lazy "solution".
System/Server Administrator - Networking - Storage - Virtualization - Scripting - Applications
https://linustechtips.com/topic/251532-hyper-v-problem/#findComment-3465668
