Hey everyone, I'm in need of your help, desperately,
It has driven me mad enough to have to post this here but here it goes.
When transferring files over an ethernet connection (or wireless) from computer to computer, is it normal for it to knock out the internet for the rest of the house?
I keep thinking it's a bandwidth issue, but I'm unsure.
I was transferring files files from my desktop to my laptop (around 50GB) As soon as it started, my brother instantly ran downstairs to have a go at me, apparently his xbox live went down (he's a console advocate). I checked and true enough, it would not connect to XBL. I tried loading a webpage on my laptop, and nothing would load. It would keep coming up saying I'm not connected to the internet, yet the file transfer was working no problem.
Now that I have stopped/paused the transfer, everything is fine again. Is it a bandwidth issue, or is it just my ISP being a dick (knowing my luck, it's a bit of both)
The same issue occurs when downloading large files (around 1GB+) the download works, but the net goes down. This is also common when downloading games on Steam (praise GabeN for not having to go to the shop any more)
My current broadband plan is this
16-18mbp/s down
0.9 mbp/s up.
I have decided to upgrade to BT Infinity Fibre, but that won't happen until next Friday (21st November), it should hopefully push my speeds up to
78Mbps down
Up to 18Mbps Up.
and BT said they wouldn't throttle the connection and it is fully unlimited.
Would this upgrade help at all?
So Recap
1: When transferring files over an ethernet connection (or wireless) from computer to computer, is it normal for it to knock out the internet for the rest of the house?
2: Would the ISP upgrade help at all for the other issues, although it would be a little too late for this current issue?
3:  Is it a bandwidth issue, or is it just my ISP being a dick (knowing my luck, it's a bit of both)
Ryze of the Phoenix:
CPU:      AMD Ryzen 5 3600 @ 4.15GHz
Ram:      64GB Corsair Vengeance LPX DDR4 @ 3200Mhz (Samsung B-Die & Nanya Technology)
GPU:      MSI RTX 3060 12GB Aero ITX
Storage: Crucial P3 1TB NVMe Gen 4 SSD, 1TB Crucial MX500, Spinning Rust (7TB Internal, 16TB External - All in-use),
PSU:      Cooler Master MWE Gold 750w V2 PSU (Thanks LTT PSU Tier List)
Cooler:   BeQuite! Prue Rock 2 Black Edition
Case:     ThermalTake Versa J22 TG
Passmark 10 Score: 6096.4         CPU-z Score: 4189 MT         Unigine Valley (DX11 @1080p Ultra): 5145         CryEngine Neon Noir (1080p Ultra): 9579
Audio Setup:                  Scarlett 2i2, AudioTechnica AT2020 XLR, Mackie CR3 Monitors, Sennheiser HD559 headphones, HyperX Cloud II Headset, KZ ES4 IEM (Cyan)
Laptop:                            MacBook Pro 2017 (Intel i5 7360U, 8GB DDR3, 128GB SSD, 2x Thunderbolt 3 Ports - No Touch Bar) Catalina & Boot Camp Win10 Pro
Primary Phone:               Xiaomi Mi 11T Pro 5G 256GB (Snapdragon 888)
https://linustechtips.com/topic/251312-i-need-your-help-please/
1. Maybe.. Are you able to see how much it uploads and downloads per second? (For example: I tried to upload something to Google Drive and everything went slow, because it was uploading 5 files a time.)
2. I don't think so, because it's in your local network.
3. Don't think so, if I am right on nr. 2.
https://linustechtips.com/topic/251312-i-need-your-help-please/#findComment-3444627
When transferring files on your local network ISP bandwidth and speeds are irrelevant. I would think it is your router having bad prioritization. Your upgrade will help with downloading and not effecting others though.
Thanks for the responses. The router I'm using is the BT HomeHub 3 which they provided. When I get the upgrade, They will provide a HomeHub 4 or 5 I believe. I keep telling my parents to get a better 3rd party Router. but they won't. Would I need a speciallised router for fibre or could I just purchase a normal dual band router and use that. That's another point, its only a single band router at the moment, so everything is operating on 2.4GHz
https://linustechtips.com/topic/251312-i-need-your-help-please/#findComment-3444661
I'm not uploading or downloading, Im doing a straight computer-to-computer connection, just using the router as a bridge point. it just so happens that when I am downloading the same issue seems to arise
https://linustechtips.com/topic/251312-i-need-your-help-please/#findComment-3444673
I don't have fiber so don't quote me on this but usually it's a special modem or a fiber to ethernet converter box once it's in your house. From there you would attach your router. You really, really should be getting a different router.
https://linustechtips.com/topic/251312-i-need-your-help-please/#findComment-3444678
So, are you on WiFi (2.4 GHz) in your house or are the laptop, your PC and the Xbox connected with an ethernet cable?
https://linustechtips.com/topic/251312-i-need-your-help-please/#findComment-3444697
I think it is FTTC (Fibre to the Cabinet) not to the house, so I think it will just be a traditional copper line to the house, don't quote me on that...
Edit: just looked and it is FTTC
https://linustechtips.com/topic/251312-i-need-your-help-please/#findComment-3444703
usually everything is on the 2.4GHz wifi, but for this transfer, I hooked my laptop and desktop up via ethernet.
https://linustechtips.com/topic/251312-i-need-your-help-please/#findComment-3444706
