Are my sockets grounded?
Go to solution Solved by ionbasa,
Didn't realize the UK doesn't use Schuko plugs. That is a BS-1363 Plug, yes it should be grounded.
How do I check? Wondering as I'm wondering about my anti static wrist strap, which will be going on my PSU, but that's not much use if the sockets not grounded. Thanks.
P.S. I know radiators are, it's just the strap will barely make it to my wooden kitchen table work surface.
https://linustechtips.com/topic/249836-are-my-sockets-grounded/
If you have a multimeter, measure the voltage from hot to ground (earth). If there is a voltage, then its safe to assume that the socket is grounded.
▶ Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning. - Einstein◀
Please remember to mark a thread as solved if your issue has been fixed, it helps other who may stumble across the thread at a later point in time.
https://linustechtips.com/topic/249836-are-my-sockets-grounded/#findComment-3425768
I don't think i do.
Well, if your are in the USA, and have a three prong outlet, then you are 99% likely to have a grounded circuit.
(the other 1 % is for improper installations where contractors cheap out and use the neutral conductor as a ground conductor as well.)
https://linustechtips.com/topic/249836-are-my-sockets-grounded/#findComment-3425778
Sorry, UK, although we have a 3 pin output.
Edit: A144FA_MAINS_LEAD_1.jpg
https://linustechtips.com/topic/249836-are-my-sockets-grounded/#findComment-3425780
Regardless, if its the 4 pin schuko outlet, you are generally speaking safe. If its a 2 pin euro plug, then no, it isn't grounded.
https://linustechtips.com/topic/249836-are-my-sockets-grounded/#findComment-3425783
Edit:
-snip-
Yeah, that looks like it is grounded to me. I'm not the best but I think it is.
 CPU Intel Core i7-4790K  | Motherboard Asus Sabertooth z97 Mark 1 | RAM Corsair Dominator Platinum 16gb 1866mhz | GPU EVGA GeForce GTX 980 w/ ACX 2.0 | Case Fractal Design Define R4 w/Window | Storage Western Digital BLACK SERIES 3TB 3.5" 7200RPM + Samsung 840 EVO 250GB |  PSU Corsiar RM750 | Display(s) Some Acer Things | Cooling Corsair H100i + 5x Noctua NF-F12 industrial 120mm fans(they are freaking load) | Keyboard Corsair Vengeance K95 |  Mouse Logitech G502 | Sound Audio-Technica AD900x + 02+ODAC +AT2020 | OS Microsoft Windows 8.1 Pro
https://linustechtips.com/topic/249836-are-my-sockets-grounded/#findComment-3425790
https://linustechtips.com/topic/249836-are-my-sockets-grounded/#findComment-3425794
all modern plugs should be grounded but thats assuming the wiring is proper and functional. to be sure you can get a device called a ground polarity tester which will verify grounded outlets. in the us they run about $10
Mac Pro 2013, 3.5GHz 6-core xeon E5, 32GB 1866 ddr3 ECC, 2x AMD Firepro d700 6GB, 512GB PCIe SSD, 3x Dell u2412m 24", Audio-technica ad-700 with Astro mixamp, Logitech g19s, Steelseries Sensei Wireless, Saitek x-55.
https://linustechtips.com/topic/249836-are-my-sockets-grounded/#findComment-3425799
As was already said, assuming everything is working correctly then it should be grounded, that's what the top pin is for (as well as opening up the bottom of some sockets).
Thanks.
Good :) I don't know anything about electricity, sounds like you do ;)
https://linustechtips.com/topic/249836-are-my-sockets-grounded/#findComment-3425828
