My First Build
Go to solution Solved by Chucky401,
http://pcpartpicker.com/user/Chucky40/saved/JRfV3C
here is what I would do if i were you
So I finally saved up enough to build my first gaming rig. I've been picking and selecting parts for a few months now and I think I'm finally ready to buy. What do you guys think?
http://pcpartpicker.com/p/ZbgpFT
Budget & uses & any monitors/pheriphials/windows?
https://linustechtips.com/topic/249485-my-first-build/#findComment-3421418
[PCPartPicker part list](http://pcpartpicker.com/p/3kLqWZ) / [Price breakdown by merchant](http://pcpartpicker.com/p/3kLqWZ/by_merchant/)
Type|Item|Price
**CPU** | [intel Core i5-4690K 3.5GHz Quad-Core Processor](http://pcpartpicker.com/part/intel-cpu-bx80646i54690k) | $214.29 @ Amazon
**CPU Cooler** | [NZXT Kraken X61 106.1 CFM Liquid CPU Cooler](http://pcpartpicker.com/part/nzxt-cpu-cooler-rlkrx6101) | $129.99 @ SuperBiiz
**Motherboard** | [Asus Z97-PRO(Wi-Fi ac) ATX LGA1150 Motherboard](http://pcpartpicker.com/part/asus-motherboard-z97prowifiac) | $207.98 @ SuperBiiz
**Memory** | [Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1333 Memory](http://pcpartpicker.com/part/kingston-memory-hx313c9fbk28) | $79.99 @ Amazon
**Storage** | [samsung 840 EVO 500GB 2.5" Solid State Drive](http://pcpartpicker.com/part/samsung-internal-hard-drive-mz7te500bw) | $238.98 @ OutletPC
**Storage** | [Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive](http://pcpartpicker.com/part/western-digital-internal-hard-drive-wd10ezex) | $54.98 @ OutletPC
**Video Card** | [EVGA GeForce GTX 970 4GB FTW ACX 2.0 Video Card](http://pcpartpicker.com/part/evga-video-card-04gp42978kr) | $379.99 @ Amazon
**Case** | [NZXT Phantom 820 (Black) ATX Full Tower Case](http://pcpartpicker.com/part/nzxt-case-caph820m1) | $219.99 @ Amazon
**Power Supply** | [Corsair RM 650W 80+ Gold Certified Fully-Modular ATX Power Supply](http://pcpartpicker.com/part/corsair-power-supply-cp9020054ww) | $109.99 @ Newegg
 | | **Total**
 | Prices include shipping, taxes, and discounts when available | $1636.18
 | Generated by PCPartPicker 2014-11-12 13:37 EST-0500 |
https://linustechtips.com/topic/249485-my-first-build/#findComment-3421435
@EnD
get an evga 750G2 psu. its much better.
swap the 4770k for a 4790k
id get another case. maybe a h440 or corsair 750d
id swap the corsair memory for some kingston fury 1866mhz ram
edit. I have the4790k and I use an h80i. works perfecly
https://linustechtips.com/topic/249485-my-first-build/#findComment-3421455
Dont use  a 4770K, use a 4790K instead, do you really need a i7? And that 1000W Is WAY overkill
My current build - Ever Changing.
Number 1 On LTT LGA 1150 CPU Cinebench R15
http://hwbot.org/users/TheGamingBarrel
https://linustechtips.com/topic/249485-my-first-build/#findComment-3421464
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($279.99 @ Micro Center)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($95.98 @ OutletPC)
Motherboard: Asus Z97-PRO(Wi-Fi ac) ATX LGA1150 Motherboard ($207.98 @ SuperBiiz)
Memory: Corsair Vengeance 16GB (4 x 4GB) DDR3-1600 Memory ($184.99 @ Newegg)
Storage: Crucial MX100 512GB 2.5" Solid State Drive ($199.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($54.98 @ OutletPC)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE 3X Video Card ($556.80 @ Newegg)
Case: Phanteks Enthoo Pro ATX Full Tower Case ($99.99 @ Newegg)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($94.99 @ NCIX US)
Total: $1775.69
Generated by PCPartPicker 2014-11-12 13:56 EST-0500
"an obvious supporter of privacy"
https://linustechtips.com/topic/249485-my-first-build/#findComment-3421550
Sorry about that. My budget is anything under $2000, I'm currently using 2 1080 monitors. This build is mostly for gaming so anything that will revolve around a good graphics card.
then check out my setup it would obliterate 2 1080p monitors and it's pretty much in your price range
https://linustechtips.com/topic/249485-my-first-build/#findComment-3421563
