I've scrounged up enough parts for my gaming box and after spending a good 2 hours looking through ITX cases nothing has really stuck out as a clear winner, I've only ruled out a few cases.
Build Specs:
G3258 until I delid a 4770k from another build
ASUS Z97i-Plus
Gigabyte GTX 970 (GV-N970IXOC-4GD)
G.Skill Trident X 2400 (2x4gb)
Samsung 840 EVO 250gb
EVGA 650 G1 (tentative)
Cooler Master Seidon 240M, maybe an H105 if it'll fit.
Case Requirements:
Space for a 240mm AIO
Slim (preferred) or 5.25" drive bay
Space for a standard sized 600-750w PSU
A dual GPU slot, although length is not a concern
The EVGA Hadron Hydro was a contender until I watched a few reviews, and the airflow/no filter/PSU just aren't going to work out. No preference on color or window, interior parts are mostly blacked out so matching isn't really an issue. I'd also rather not build in a BitFenix Prodigy again, and lack of a slim drive (or 5.25" w/rad) is a no go.
Open to any suggestions :D
Picked up a 250D, modded to fit an H105, and it's one hell of a little gaming box. Thanks everyone!
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
https://linustechtips.com/topic/248563-help-me-pick-an-itx-case/
air 240; it's a little on the big size for m-itx but it offers a lot.
edit: lack 5.25 drive. I'll keep looking.
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
https://linustechtips.com/topic/248563-help-me-pick-an-itx-case/#findComment-3409133
Still on the fence about a cube, have to somehow fit this thing next to a 55" TV and tower speakers. Although, I do like the Air's
https://linustechtips.com/topic/248563-help-me-pick-an-itx-case/#findComment-3409142
Use an external optical drive, they're cheap and work well. :P
System 1: Thermaltake Element Q - Thermaltake 220W SFX - Asus AT5IONT-I mini-ITX - Intel® Atom™ D525 onboard 1.8GHz Dual-Core HT - Integrated NVIDIA® ION™ - 2x 2GB Kingston DDR3 - Samsung 120GB 840 Series - Scythe Kama Rack 3.5 - Asus DVD-RW
System 2: Thermaltake Element Q - Thermaltake 220W SFX - Asus E2KM1I-DELUXE mini-ITX - AMD E2-2000 onboard 1.75GHz Dual-Core - Integrated AMD® Radeon HD 7340 - 2x 4GB Kingston DDR3 - Samsung 120GB 840 Series - Scythe Kama Rack 3.5 - Asus DVD-RW
Building: Bitfenix Prodigy Black - Corsair AX860i - Asus Maximus VII Impact - Corsair Hydro Series H100i - Intel® Core™ i7 4790K - Asus Matrix Platinum GTX 980 4GB - Corsair 16GB Dominator Platinum 2x 8GB DDR3 2400MHz CL10 - Samsung 1TB EVO 840 Series
https://linustechtips.com/topic/248563-help-me-pick-an-itx-case/#findComment-3409151
and look like shit, with USB 2.0 transfer rates :P
I'd prefer no drive at all, but the wife would appreciate being able to throw in a DVD/Blu Ray from time to time.
https://linustechtips.com/topic/248563-help-me-pick-an-itx-case/#findComment-3409155
They don't look like shit at all, I have a Asus SDRW-08D2S-U LITE and looks nice.  :P
And the Asus BW-12D1S-U is USB 3.0.
http://www.asus.com/Optical_Drives/BW12D1SU/
https://linustechtips.com/topic/248563-help-me-pick-an-itx-case/#findComment-3409227
Fun fact: Mini-ITX motherboards can be mounted in a Corsair Obsidian 900D with room to spare.
I cannot be held responsible for any bad advice given.
I've no idea why the world is afraid of 3D-printed guns when clearly 3D-printed crossbows would be more practical for now.
My rig: The StealthRay. Plans for a newer, better version of its mufflers are already being made.
https://linustechtips.com/topic/248563-help-me-pick-an-itx-case/#findComment-3410078
Are you dead-set on the full size power supply? If not you could go for something like the FT-03 Mini from Silverstone, pretty tower-y looking if you ask me.
Tentative winner here!
I'll have to mod a quick release bracket to mount the 240mm rad externally, but the top cut-out allows the block/tubes to be routed inside relatively easily. Having to use a SX-600 hurts the wallet a bit, but it looks pretty clean.
https://linustechtips.com/topic/248563-help-me-pick-an-itx-case/#findComment-3411070
Your build would be fine with the 450 watt SFX supply from silverstone, no need for the 600 unless you were going for something like an OC 980 + OC 4790k, any 970 will be absolutely fine as it has similar power consumption to a 760.
https://linustechtips.com/topic/248563-help-me-pick-an-itx-case/#findComment-3411656
If you are willing to sacrifise AIO
FT03-mini
If not
lian li pc-q36
https://linustechtips.com/topic/248563-help-me-pick-an-itx-case/#findComment-3411693
FT03-mini
If not
lian li pc-q36
You can still have a 120mm AIO in the FT-03 mini - it's been done by a few people if you look around.
Also here are results from Anandtech for power consumption of an entire system (with a 4960X at 4.2GHz) with a 970 in - NOT just the card
https://linustechtips.com/topic/248563-help-me-pick-an-itx-case/#findComment-3411728
Yeah, he said a 240mm one tho
The 240mm would fit in the pc-q36
https://linustechtips.com/topic/248563-help-me-pick-an-itx-case/#findComment-3411800
planning on swapping to a 4770k (OC) down the road and flashing the BIOS of the 970... I'd rather have more than enough overhead than barely enough.
https://linustechtips.com/topic/248563-help-me-pick-an-itx-case/#findComment-3412695
no one has mentioned this but i love inwin cases here are a few examples:
Inwin H frame mini:
Inwin D frame mini:
I like them but I can't do open air, cat would be shredding it up day one :lol: Although it looks like a few of their cases are completely sealed.
https://linustechtips.com/topic/248563-help-me-pick-an-itx-case/#findComment-3412702
FT03-mini
If not
lian li pc-q36
Can't sacrifice AIO, and I can build a bracket to have it exterior mounted, the case just needs to have one side large enough (240mm).
https://linustechtips.com/topic/248563-help-me-pick-an-itx-case/#findComment-3412715
The lian li PC-q36 can do that
https://linustechtips.com/topic/248563-help-me-pick-an-itx-case/#findComment-3412788
Don't know if anybody has suggested as I haven't read the whole thread but would a BitFenix Prodigy do? It can house Micro ATX as well.
https://linustechtips.com/topic/248563-help-me-pick-an-itx-case/#findComment-3413628
Mentioned not wanting to build in a Prodigy in my OP.
https://linustechtips.com/topic/248563-help-me-pick-an-itx-case/#findComment-3413648
Ah I sees. EVGA Hadron? As long as you use EVGA's disc drive slim thing you're good.
EDIT: Hadron is also out, umm OK... lemme get back to ya.
https://linustechtips.com/topic/248563-help-me-pick-an-itx-case/#findComment-3413676
