Do you guys have overclocking guide for Asus x99 deluxe/i7-5930k?
Corsair 760T White | Asus X99 Deluxe | Intel i7-5930k @ 4.4ghz | Corsair H110 | G.Skill Ripjawz 2400mhz | Gigabyte GTX 970 Windforce G1 Gaming (1584mhz/8000mhz) | Corsair AX 760w | Samsung 850 pro | WD Black 1TB | IceModz Sleeved Cables | IceModz RGB LED pack
https://linustechtips.com/topic/246157-overclocking-guide/
Up the voltage and multiplier; that's how easy overclocking has become.
You can get real nitty gritty with all the parameters as well, but it's really that simple.
If your intent is to not squeeze every last megahert out of the cpu, then increase voltage and multiplier. You can still get an amazing overclock this way too.
https://linustechtips.com/topic/246157-overclocking-guide/#findComment-3378995
Its basically the same thing as this.
https://linustechtips.com/topic/246157-overclocking-guide/#findComment-3379015
Thanks for the help guys!
https://linustechtips.com/topic/246157-overclocking-guide/#findComment-3379033
