I was running my computer on a box beside my desk with no case on it, and when I O.C'ed my 5820k and ran prime95 for 12 hours it didn't get any hotter than 64 degrees. I managed to get it to 4.3GHz without touching the voltage at all.  I got my case today, and while playing BF4 I noticed it got up to 82 degrees. Should I back my O.C. down a few notches? Or will it make much of a difference? I REALLY don't wanna burn out the first truly beastly computer I've ever owned.
https://linustechtips.com/topic/246098-oc-temps/
I'd say bring back the OC just a bit if you'r ereallly worried. But it should be fine. Depending on your cooling setup.
Love the Profile Pic by the way. Avenged is my favorite band, Was my first concert.
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/246098-oc-temps/#findComment-3378157
whats your cooling setup?
and gpu heat was probably causeing higher cpu heat.
And nah 82 is fine
Kraken x61, but only with one fan cause I kinda had to rig it in there, the Phantom doesn't technically support the x61.
https://linustechtips.com/topic/246098-oc-temps/#findComment-3378175
82c is a bit too high for comfort
"Rawr XD"
https://linustechtips.com/topic/246098-oc-temps/#findComment-3378176
Not even overclocked. I call these YOLO temps on my shittop.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/246098-oc-temps/#findComment-3378684
