In need of some headphone help please.
Solved by Onyxius,
What makes you think the sound could be better?
Mixamp pro isn't going to be any better than the STX, nor is the FiiO E09K. The Magni is a decent cheap amp, but I really doubt any amp is going to make a huge difference if your onboard sounded better to you than the soundcard. If you're going for fancy surround sound your only option other than a soundcard is Razer Surround software, which I know you already said you gave up on quite quickly.
Well i figured without the sound card i can tell the volume is much lower so maybe the magni and modi together could make it sound even better.
