So 850 pro offers total 50TB of read and write,40GB perday over 10 year period.We read data more than we write,right?.I mean if I play 2 games which takes up space of total 100gb?.Is that SSD gonna die soon?
No, it will last you "forever" -- you'll be replacing it with something better long before it goes bad.
/It's writing which "damages" ssds.
P.s. the same will be true with the 840 Evo or MX100 (or pretty much any other decent ssd on the market)
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/244585-ssd-daily-read-question/#findComment-3356445
Actually even writing isnt a problem:
http://techreport.com/review/26523/the-ssd-endurance-experiment-casualties-on-the-way-to-a-petabyte
Many/Some SSDs will even handle up to 1000 TB write.
Christopher Kruse | Webdeveloper (Interface & Applications)
i7 3770k (3233C Batch) @ 4.2ghz | Asus P8Z77 WS | Gigabyte 780 Ti OC  | Corsair Vengeance LP 1600 32GB DDR3 | Samsung 850 EVO 500GB +2x Samsung 840 EVO 250GB + Samsung 830 256GB + 4x WD30EFRX, 2x WD30EZRX, 1xWD20EARS | Corsair AX750 + Bitfenix Extensions | Fractal Design Define XL R2 + Xigmatec 3in3 Hotswap Cage | Noctua NH-D15 + Thermal Grizzly Kryonaut, 5x Noctua NF-P14s redux-1500 PWM | Peripherals: Logitech G502 + Corsair K70 RGB + Red 40A-L O-Rings | Sound: Denon AVR 2807 via HDMI + 2x Nubert nuPro A-20 + 1x B&W CC6 Center | SoundMagic E10 | Jabra Speak 410
https://linustechtips.com/topic/244585-ssd-daily-read-question/#findComment-3356466
People say that they should start making m2 ports SSD,but those are already available?
https://linustechtips.com/topic/244585-ssd-daily-read-question/#findComment-3356468
The Plextor M6e...something already exists, but its twice as expensive and only a bit faster.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820249046&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
PSU Tier List | CoC
https://linustechtips.com/topic/244585-ssd-daily-read-question/#findComment-3356476
http://techreport.com/review/27062/the-ssd-endurance-experiment-only-two-remain-after-1-5pb
A bit more relevant, up to 1500 Tb
Any unknown button should be pressed even number of times.
https://linustechtips.com/topic/244585-ssd-daily-read-question/#findComment-3356490
Reads are unlimited with flash memory (tech inside ssds) so you can read as much as you can. Writing does hurt SSDs lifespan, but you'd have to hammer it very hard for it to die any time soon.
+°´°+,¸¸,+°´°~ Glorious PC master gaming race :wub: ~°´°+,¸¸,+°´°+
BigBox: Asus P8Z77-V, 3570k, 8GB Ram, Intel 180GB & Sammy 750GB, HD4000, W7
PiBox: Rasberry Pi, BCM @ 1225Mhz ^_^ , 256MB Ram, 16GB Storage, pIO, Raspbian
https://linustechtips.com/topic/244585-ssd-daily-read-question/#findComment-3356505
Yeah :P Was to lazy to search for the newest article about the experiment, thanks
https://linustechtips.com/topic/244585-ssd-daily-read-question/#findComment-3356511
Bottom line: even a "slow user grade SSD" such as the 840 EVO/MX100 etc will most likely not die on you because you have reached the limits of writes on the drive.
You'll probably need a better SSD (SATA Express, for example) or a bigger SSD before your "old" one dies so I don't really see the point of buying expensive SSDs if you're not using it for professional meanings.
CPU: Intel Core i7-4790k | CPU Cooler: Noctua NH-D15 | Motherboard: ASUS Sabertooth Z97 MARK 1 | Memory: Kingston HyperX FURY 16GB 1866MHz | GPU: Gigabyte GeForce GTX 770 4GB Windforce
Storage: Samsung 840 EVO | PSU: CM Silent Pro 720W | Case: Phanteks Enthoo Luxe | Headset: Corsair Vengeance 2100 | Keyboard: Logitech G710+ | Mouse: Razer DeathAdder Chroma
"You see, one can only be angry with those he respects." - R. Nixon
https://linustechtips.com/topic/244585-ssd-daily-read-question/#findComment-3356653
