AMD Graphics Cards Help
Go to solution Solved by Briggsy,
R9 = GTX
R7 = GTX/GTS
R5 = GT
different tiers really. 7000 series naming scheme is obsolete, but are still relevant because they were designed to be future proof for 4-5 years.
I'm a Nvidia fanboy but I want to be rehearsed on Amd's graphics card's naming. So, how are they named? What's the difference between a r9 and a 7000?
Read the LTT Beginner's Guide; it's like a guide on how to not be a moron
 CPU: i5-4690k 4.1 GHz CPU Cooler: Cooler Master 212 EVO GPU: Asus Gtx 970 Strix MOBO: ASUS Z97-E RAM: Crucial Ballistix Sport 16GB (2 x 8GB) 1600 SSD: Samsung 840 Evo 500GB HDD: Seagate Barracuda 1TB PSU: Cooler Master 600W 80+ Bronze Case: Cooler Master Storm Scout 2 Advanced
https://linustechtips.com/topic/243618-amd-graphics-cards-help/
7000/6000/5000 is the old naming scheme of their cards before they changed the r7/r9 with their newer cards.
https://linustechtips.com/topic/243618-amd-graphics-cards-help/#findComment-3336174
If you want to compare naming schemes on cards check this thread that @Speedbird made http://linustechtips.com/main/topic/222806-what-rx-200-series-card-is-what-7000-series-card/
Specs: CPU: AMD FX 6300 Motherboard: Gigabyte 970A DS3P RAM: HyperX Fury 16GB 1866MHz GPU: MSI R9 270 OC edition Case: Sharkoon VS3-S SSD: Samsung 840 EVO 120GB HDD: 1TB Caviar Blue PSU: Corsair CX500W
*If I say something that seems offensive, please don't take it seriously, it was most likely meant as a joke/sarcastically*
https://linustechtips.com/topic/243618-amd-graphics-cards-help/#findComment-3336181
Thanks for bringing this up. Link also in my sig.
LTT's unofficial Windows activation expert.
https://linustechtips.com/topic/243618-amd-graphics-cards-help/#findComment-3336238
R9 is the top range, the 7000 series is the old series and R7 is the budget series (new)
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/243618-amd-graphics-cards-help/#findComment-3336260
R9 = GTX
R7 = GTX/GTS
R5 = GT
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
https://linustechtips.com/topic/243618-amd-graphics-cards-help/#findComment-3336409
