best CPU/ motherboard
Go to solution Solved by SeanAngelo,
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£173.00 @ Amazon UK)
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard  (£94.99 @ Amazon UK)
Total: £286.67
Generated by PCPartPicker 2014-10-31 00:53 GMT+0000
so my friend has about £280 to spend on a new CPU and motherboard because he is planning on getting a 970 for Christmas. he has the RAM so its just the CPU MOBO and cooler if the CPU dont come with one.
l Intel Core i7 4790K @ 4.5Ghz l Asus VII Ranger ROG l MSI GTX 970 @ 1555MHz l
PC PART PICKER
https://linustechtips.com/topic/241885-best-cpu-motherboard/
Core i5-4590 and H97 motherboard for budget...i5-4690K and Z97 if he can afford it and hyper 212 by cooler master as CPU cooler for cheap...good for overclocking.
Both CPU comes with a descent enough CPU heatsink...both won't ''require'' the hyper 212...i suggest it just in case he would want to overclock the i5-4690K.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/241885-best-cpu-motherboard/#findComment-3315273
Total: £286.67
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/241885-best-cpu-motherboard/#findComment-3315278
Total: £286.67
do you know if that GPU cooler will fit in the antec 300 and i like this one
PC PART PICKER
https://linustechtips.com/topic/241885-best-cpu-motherboard/#findComment-3315300
How bad is his current cpu if he has to upgrade to use an gtx 970?
what does he need his cpu for? you cant just ask for the best cpu it depends on what he is going to do with it and how much money he is willing to spend
well he is currently using a i3 2120 and he will be mostly gaming on it with some small rendering. games are BF4 ARMA mincraft ect
PC PART PICKER
https://linustechtips.com/topic/241885-best-cpu-motherboard/#findComment-3315336
Defenetly an intel core i5...locked or unlocked depending on the budget.
https://linustechtips.com/topic/241885-best-cpu-motherboard/#findComment-3315342
yea because he was going to get the 970 first but i talked him out of it because it would have been such a bottle neck
PC PART PICKER
https://linustechtips.com/topic/241885-best-cpu-motherboard/#findComment-3315358
it will fit, the cpu cooler is only 130mm high, the antec 300 can take up to 170mm.
Old Rig
https://linustechtips.com/topic/241885-best-cpu-motherboard/#findComment-3315384
CPU: Intel Xeon E3-1230 V2 3.3GHz Quad-Core Processor  (£175.79 @ Scan.co.uk)
Total: £175.79
Generated by PCPartPicker 2014-10-31 01:14 GMT+0000
Why upgrade to haswell when his motherboard would work with a 1230v1 or v2.
Computing enthusiast.
I use to be able to input a cheat code now I've got to input a credit card - Total Biscuit
https://linustechtips.com/topic/241885-best-cpu-motherboard/#findComment-3315395
ok cool cool see what i did there haha thanks any way
PC PART PICKER
https://linustechtips.com/topic/241885-best-cpu-motherboard/#findComment-3315396
Total: £175.79
because its a really cheap MOBO
PC PART PICKER
https://linustechtips.com/topic/241885-best-cpu-motherboard/#findComment-3315399
well...a sandy bridge core i3 is defenetly not what you want to pair with such a strong GPU that's for sure...but if he can only afford the GPU it's a good way to shoot high and consider a cpu upgrade as soon as he gets money for it...but yeah, this kit won't break the bank and will get the job done for a long time:
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor ($179.99 @ NCIX US)
Motherboard: MSI Z87-G41 PC Mate ATX LGA1150 Motherboard ($53.00 @ Newegg)
Total: $232.99
Generated by PCPartPicker 2014-10-30 21:16 EDT-0400
https://linustechtips.com/topic/241885-best-cpu-motherboard/#findComment-3315400
