if your PSU doest have a PCIe power connector, then you can get a 750ti as it is powered directly from the motherboard
First Build:
Case: Bitfenix Prodigy Black          GPU: MSI R9 270 Gaming@1050/1500         CPU: i5 4570          Motherboard: ASUS H81I Plus          PSU: Corsair CX600          RAM: 8GB Crucial Ballistix Sport XT         Cooling: 230mm Bitfenix Spectre Pro Intake; Corsair AF140 Rear Exuast; 2x120mm Stock Case Fans Top Exuast        Storage: WD Blue 1TB          OS: Windows 8.1 Pro 64 Bit
https://linustechtips.com/topic/241605-i-need-help/#findComment-3311656
It's up to the board partners to add power connectors if they need to, so its possible that some factory overclocked 750 Ti's may need a PCIe power connector even though the reference card doesn't. Just make sure you're checking.
https://linustechtips.com/topic/241605-i-need-help/#findComment-3311759
Didnt realize that. I found some models by Asus, Msi, Zotac and EVGA that dont require extra power:
http://www.amazon.co.uk/GeForce-Graphics-Express-128-bit-Dust-Proof/dp/B00IITDIHM/ref=sr_1_2?ie=UTF8&qid=1414686677&sr=8-2&keywords=asus+750ti
http://www.amazon.co.uk/Zotac-GTX750-GeForce-Internal-Graphic/dp/B00IFZ547Q/ref=sr_1_1?ie=UTF8&qid=1414686799&sr=8-1&keywords=zotac+750ti
http://www.amazon.co.uk/MSI-OC-1059MHz-DL-DVI-D-Graphics/dp/B00I5ZYI5A/ref=sr_1_2?ie=UTF8&qid=1414686861&sr=8-2&keywords=msi+750ti
http://www.amazon.co.uk/EVGA-1176MHz-1255MHz-5400MHz-Graphics/dp/B00IGQ4Z3S/ref=sr_1_1?ie=UTF8&qid=1414686931&sr=8-1&keywords=evga+750ti
there are some others from brands like galaxy and palit aswell.
First Build:
https://linustechtips.com/topic/241605-i-need-help/#findComment-3311839
Adding an r9 series is wayy to overkill seriously , this board even uses gen 1 pci express
check the specs
http://204.14.213.185/Product/Product.aspx?Item=N82E16813128334
I would say max 650ti , anything else would be bottlenecking the gpu.
Rig:Crimson Impaler | CPU: i3 4160 | Cooler: CM Hyper TX3 Evo | Motherboard: Asrock B85M - DGS | RAM: Kingston Hyper X Savage 16GB kit (2x8) DDR3 1600MHZ CL9 | GPU: Asus Radeon R7 360 | PSU: Corsair CX 430 V2 | Storage: HDD WD 1TB Blue | Case: Delux DLC-MG866
~Half the world is composed of idiots, the other half of people clever enough to take indecent advantage of them.~
https://linustechtips.com/topic/241605-i-need-help/#findComment-3311873
