never go too low on the watts, i would say a 80+ bronze 500w-600w will be plenty and gives you headroom for the future. (go with a trusted brand, never skimp on the heart of your pc)
I5-8600K - GTX 1080 - 16GB RAM - 1.5TB SSD
I want everything pink
https://linustechtips.com/topic/241544-how-much-watt-do-i-need/#findComment-3310712
If you were using AMD GPUs I would say over 9000! But since you got Nvidia GPUs I say 850 watts for OC headroom, expension headroom.
PC : | CPU: Intel 4790K | COOLER: Corsair H105 w/ JetFlo's Push/Pull | MOBO: EVGA Z97 Classified | GPU: EVGA FTW 4GB GTX 970 X2 | RAM: Kingston HyperX Beast 1866Mhz 32GB | CASE: HAF Stacker 945 | PSU: Corsair AX1500i | DISPLAY: Asus MX299Q | SSD: 2 X Corsair Neutron GTX 480 GB in RAID0 | mSATA SSD: Samsung 840 EVO 500 GB | HDD: 4 X Western Digital RED 4 TB in JBOD |
https://linustechtips.com/topic/241544-how-much-watt-do-i-need/#findComment-3310714
600w would be fine, I'd suggest the corsair cx600m.
https://linustechtips.com/topic/241544-how-much-watt-do-i-need/#findComment-3310721
Dear AMD GPU user, his post says he's using 2-way SLI setup.
https://linustechtips.com/topic/241544-how-much-watt-do-i-need/#findComment-3310723
This is some next level overkill 850W. SLI GTX 570 will draw about 600W on full stress so if you want headroom as well go for the EVGA G2 750W.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/241544-how-much-watt-do-i-need/#findComment-3310724
i just wanna buy a new PSU for my PC i will upgrade it soon my SPEC is
Xeon X5650 6C12HT
X58 Sabertooth
Gskill BUS2000 10GB 2X5
SSD V300
WD Black 500GB
WD Blue 750GB
GTX 570 DCU2 SLI2 ways
Lots of wats!
"Use the force Harry"
                   -Gandalf
https://linustechtips.com/topic/241544-how-much-watt-do-i-need/#findComment-3310727
He's not using a tiny i5.
https://linustechtips.com/topic/241544-how-much-watt-do-i-need/#findComment-3310744
Waaaaaatt?
Use a PSU Calculator from Corsair/CoolerMaster/NCIX/Newegg and pretty much everyone else in the planet.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/241544-how-much-watt-do-i-need/#findComment-3310757
some people suggest me Seasonic M12II 850W EVO is worth?
No need for a 850w. A decent 750w is already plenty.
Where are you shopping/located? Budget?
You need to quote a post or tag a member or else they won't get a notification you replied to them.
https://linustechtips.com/topic/241544-how-much-watt-do-i-need/#findComment-3312932
600-700 Watt power supply is pretty enough!  :)
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/241544-how-much-watt-do-i-need/#findComment-3312971
