Hey guys. Something in my system is making a rattling noise but I'm not sure what is is. I think it is one of the fans but I can't be sure. Is there any way I can turn the fans off one by one via software to isolate the problem?
Edit: I am using the NZXT s340 case with the two stock fans and a NZXT Kraken x61 with the two white radiator fans in the front intake. So that makes four fans all together. 2 chassi and 2 white kraken ones.
https://linustechtips.com/topic/241439-fan-making-noise/
Just open your case while it's running and you should be able to tell by ear which fan is causing you problems
"Common sense is not so common." -Voltaire
https://linustechtips.com/topic/241439-fan-making-noise/#findComment-3309573
Just use your hands to stop the fans.
https://linustechtips.com/topic/241439-fan-making-noise/#findComment-3309593
I'm starting to think its coming from the pump. I have a kraken x61. Is this possible? and if so, is it a problem?
the rattling only seems to happen on lower speeds using the kraken for some reason
If it's the pump there's not much you can do about it.The only think you can do is attach a 1n4001 diode so you can control the voltage
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
https://linustechtips.com/topic/241439-fan-making-noise/#findComment-3309669
Just DON'T put your finger in blades. Use the round middle part.
And to answer question about software based shutdown, you need PWM fans for that.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/241439-fan-making-noise/#findComment-3311981
