Asus Sabertooth - Top fan headers
Solved by Enderman,
It has two assistant fans, but three assistant fan headers, which is why I'm confused. I want to connect my two radiator fans into the CPU Fan and CPU Opt, but can I connect my pump to the three-pin assistant fan header?
Ah then its just an extra fan header for anything you want. Yes you can plug your pump in there
Featured Topics
Imwickman ·
Posted in Troubleshooting0 -
AlDowy ·
blu-iwnl ·
BrodieWool ·
Hichem922 ·
Posted in Troubleshooting10 -
5
4
1
1
Hichem922 ·
Posted in Troubleshooting2
