Help with picking a mobo
Solved by Sintezza,
I play games such a minecraft, GTA V (When is comes out) and Battlefield 4. (All at 1920 by 1080p) I also enjoy streaming.
ah okay, yeah wenn you like to stream aswell, and you are on a tighter budget
Then FX8350 might be a good choice indeed.
The i5-4690K will offcourse be better for gaming, But gaming + streaming, the FX8350 might be a better choice.
Unless you could stream using Qsync, But i dont realy know how well Qsync works.
But i suppose some guys with more knowledge about qsync will jump in.
THe only thing i do hope, is that this topic doesnt get screwed by all the intel fanboys, like most other topics about AMD. ![]()
