Hi,
I have a Swiftech MCP35x in my water cooling system, my question is the following:
What is the typical durability of a pump like this one?
I make this question because mine has made 4 years I don't want to risk my computer with a old pump. Should I replace it now before it fails, or will I probably be fine for a few more years?
Thanks in advance to your answers.
https://linustechtips.com/topic/241007-water-pump-durability/
Unless you hear unusual noise from it, it should last a bit longer.
MTBF is 50000 hours, and one year is about 9000 hours if you have it on 24/7, so it will probably last a year or two more.
You can replace it with something more durable and powerful like a D5 if you want to be safe.
https://linustechtips.com/topic/241007-water-pump-durability/#findComment-3303600
How long would the pump in an H110 last?
Dubs are better than subs
https://linustechtips.com/topic/241007-water-pump-durability/#findComment-3303673
Well they dont give an MTBF, but usually pumps last between 50k and 100k hours
https://linustechtips.com/topic/241007-water-pump-durability/#findComment-3303780
