I made a mistake when installing my CPU (i5-4690k) to my motherboard (Asus Maximus Hero 7). I forgot to remove the plastic CPU socket guard before installing the CPU, and installed the stock CPU cooler with the guard still on.
After realizing my mistake, I removed the CPU cooler and the plastic socket guard, and reinstalled the CPU. My problem is that some of the preinstalled thermal paste was removed in the process of removing the stock CPU cooler.
What do you guys suggest I do to fix the problem? Is the remaining thermal paste enough, or should I get some thermal paste and reapply it?
https://linustechtips.com/topic/240732-thermal-paste-problem/
Definitely reapply. There are air pockets already there. It will severely affect cooling performance.
So you removed the socket cover, installed the cpu, put the socket cover back and install the cooler? Haha
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
https://linustechtips.com/topic/240732-thermal-paste-problem/#findComment-3300093
Clean off the heatsink and get some new thermal paste to use.
Or you could just put some tooth paste on it.
DO NOT DO THIS ^ IT IS VERY BAD!
https://linustechtips.com/topic/240732-thermal-paste-problem/#findComment-3300113
Not exactly.  I installed the CPU into the socket with the socket cover still on, then tried installing the cooler.  I do feel really dumb after doing it, though.
https://linustechtips.com/topic/240732-thermal-paste-problem/#findComment-3300147
Any good brands that make thermal paste?  Arctic Silver is good, right?
Yeah arctic silver is a good one.
https://linustechtips.com/topic/240732-thermal-paste-problem/#findComment-3300179
No, AS5 is really old, and actually performs worse than a lot of new thermal paste that has been released.
I always recommend MX4, but NH-T1 and IC diamond are really good too.
https://linustechtips.com/topic/240732-thermal-paste-problem/#findComment-3300221
Always have thermal paste.....its a must. Always reapply if you aren't sure.
The Mistress: Case: Corsair 760t   CPU:  Intel Core i7-4790K 4GHz(stock speed at the moment) - GPU: MSI 970 - MOBO: MSI Z97 Gaming 5 - RAM: Crucial Ballistic Sport 1600MHZ CL9 - PSU: Corsair AX760  - STORAGE: 128Gb Samsung EVO SSD/ 1TB WD Blue/Several older WD blacks.
https://linustechtips.com/topic/240732-thermal-paste-problem/#findComment-3300231
To clean off the existing residue from the heatsink you will need a soft cloth and 99% rubbing alcohol. Soak the cloth and scrub away (don't use an abrasive cloth!) at the heatsink until the cloth comes away completely clear and clean. Then let it dry completely.
You apply one dot of paste to your CPU about the size of a small green pea. Put it right in the middle of the CPU and then lower the heatsink directly down onto it.
Intel Inside. Overweight guy in his 30's outside.
https://linustechtips.com/topic/240732-thermal-paste-problem/#findComment-3300438
Is it safe to dry it with a soft cloth, or should I let it "air out"?
https://linustechtips.com/topic/240732-thermal-paste-problem/#findComment-3300469
No, Arctic Silver is not good.  It doesn't perform well, and it is conductive.
Here is a graph:
-Tom's
I personally use Gelid GC-Extreme.  It is also amazing for your GPU.
Other good brands are, but not limited to: IC Diamond, Arctic MX-4, Noctua NT-H1, Prolimatech PK-3.
The Prolimatech PK-3 was on sale on Amazon for $7 the other day, check if it still is.  That is some excellent TIM for the price.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/240732-thermal-paste-problem/#findComment-3300546
Nice to hear when I have as5 in my brand new PC lol...
The performance with wc which I'm on, the difference is 1°, so I can live with that, but however, the part about it being conductive got me worried tho, but I should be alright if there's no overflow of thermalpaste from the CPU, right?
Cpu: Intel i7-5930k Mobo: Asus Rampage V Extreme Ram: G.skill Ripjaws 4 4x4gb 2666mhz Gpu: Gigabyte GTX 970 G1 Gaming
PSU: Evga Supernova G2 850W Storage: Samsung 850 Pro SSD 512gb Case: Phanteks P400S CPUcooler: Corsair H110 OS: Win 8.1
https://linustechtips.com/topic/240732-thermal-paste-problem/#findComment-3301327
If the paste gets in the socket you're pretty much screwed. That motherboard is finished. That's why I never use AS5. Stuff like NTH1 performs better and is cheaper to boot!
https://linustechtips.com/topic/240732-thermal-paste-problem/#findComment-3301350
Its useally fine, and AS5 isn't conductive, and if you clean it out of the socket carefully, its fine. I've had it happen 3 or 4 times at work, and never killed a board in that fasion.
It's not conductive, it's capacitive. And yes it is look it up this is a well known fact.
https://linustechtips.com/topic/240732-thermal-paste-problem/#findComment-3301387
