So I have been wondering, what is the absolute best CPU cooler, I don't care about noise and shit, I want one that will keep my CPU cool af so I can overclock it to hell and back. So I hear Noctua has some good Tower coolers like the NH-D15, but there is also water cooling options. Thanks in advance for the help guys, means a lot!
I have a I7-4790K I want to cool better so I can overclock it high. I have it right now at 4.5 Stable with a Hyper Evo 212 at 1.3V
https://linustechtips.com/topic/240686-best-cpu-cooler/
Don't care about noise? H110 with deltas :D
Sensible: Something like the Nepton 280L
Specs: CPU: AMD FX 6300 Motherboard: Gigabyte 970A DS3P RAM: HyperX Fury 16GB 1866MHz GPU: MSI R9 270 OC edition Case: Sharkoon VS3-S SSD: Samsung 840 EVO 120GB HDD: 1TB Caviar Blue PSU: Corsair CX500W
*If I say something that seems offensive, please don't take it seriously, it was most likely meant as a joke/sarcastically*
https://linustechtips.com/topic/240686-best-cpu-cooler/#findComment-3299438
Swiftech H240x
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/240686-best-cpu-cooler/#findComment-3299455
NZXT Kraken X61, Corsair H110, Swiftech H240X
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/240686-best-cpu-cooler/#findComment-3299500
Dark Rock Pro 3?
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
https://linustechtips.com/topic/240686-best-cpu-cooler/#findComment-3299562
Cryorig R1 ULTIMATE!!!!!  ;)
CPU: Intel Core i5-4670K @4.5Ghz | Motherboard: ASRock Z87 Extreme 4 | Cooler : Cryorig R1 Ultimate | Ram: 2x4GB G.Skill Ripjaws | GPU : Gigabyte GeForce GTX 970 G1 Gaming 2-Way SLi | Storage: 120GB Samsung 840 Evo / 4x2TB Caviar Black | PSU: EVGA Supernova 1000W G2 | Windows 7 64-bit  | Case: Enthoo Pro | オール・イズ・バニッティー (all is vanity)
If you work hard, you can make your own Luck.
https://linustechtips.com/topic/240686-best-cpu-cooler/#findComment-3300819
that wouldn't work delta fans are 120mm so you would loose loads of efficiency, a h105 with deltas though..........
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/240686-best-cpu-cooler/#findComment-3305941
A lot of people are suggesting the Kraken X61, I looked it up, it looks pretty good. Still not sure on what I want to go with. Thanks for the feedback so far! Also the H100i interests me. Can anyone compare the two?
The h100i isn't worth getting if you're going for the best. http://www.hitechlegion.com/reviews/cooling/liquid/41521-nzxt-x61-280mm-liquid-cpu-cooler-review?showall=1&limitstart=
You should be looking at the x61 or H240x for aio's or the NH-D15 for air cooling.
https://linustechtips.com/topic/240686-best-cpu-cooler/#findComment-3305970
