I now the GPU is fine, and of course the iGPU will be turned off for less heat.
All the specs of the CPU right here: http://www.newegg.com/Product/Product.aspx?Item=N82E16819113356
And if you prefer PCPartPicker: http://pcpartpicker.com/part/amd-cpu-ad679kwohlbox
Edit:
I've seen that in a certain benchmarking site, my CPU is 3 times what is minimally needed for SC, but only ~65% what is recommended.
https://linustechtips.com/topic/240019-my-rig-running-sc/#findComment-3291002
Edit:
Recommended specs mean nothing yet. It is all up to debate and too early to say what hardware will be needed to run the game, although we know that Star Citizen will be CPU (and GPU) heavy.
New to Star Citizen? Look no further!
https://linustechtips.com/topic/240019-my-rig-running-sc/#findComment-3291112
With a 280? Around what frames will I be hitting?
cant remember. I used two in cf and got around 60 something on high settings but I have a better cpu then you so that's also something to consider.
If I still had my itx pc I could check but I sold it :) and im to lazy to open up my current pc to swap gpu just to test.
https://linustechtips.com/topic/240019-my-rig-running-sc/#findComment-3291843
My athlon x3 450 really struggled and I was lucky to get 20-30fps on it, you have an extra core so that might be enough to push you to a stable 30fps
Arena Commander is CPU heavy at the moment and currently pushing my 8350 to use all 8 cores whereas the last 2 usually sit idle on most other games, its hit or miss ATM.
https://linustechtips.com/topic/240019-my-rig-running-sc/#findComment-3291949
And more cache and GHz.
So, I'm guessing I'll get around 35 FPS on Low-Medium on SC? That seems to be the case, with all that I've looked at.
https://linustechtips.com/topic/240019-my-rig-running-sc/#findComment-3297722
Yeah I should think so. Which should be playable as you don't really notice 30fps unless your turning sharply.
https://linustechtips.com/topic/240019-my-rig-running-sc/#findComment-3299608
