I just got it installed and will have a review of it with folding temperatures vs stock cooling.
My Computer
Beef Cake
Intel i5 4690k @ 3.5GHz - EVGA 970 FTW - ASRock Z97 Extreme3 - Kingston HyperX Fury 8Gb 1866MHz - 120GB Samsung Evo - 1TB Toshiba Drive - 320GB Samsung Barracuda - Corsair 500M
https://linustechtips.com/topic/238525-cooler-master-hyper-212-evo/
Too bad it doesn't(sorta) fit in my case...
I don't think it fits mine either but I don't put the side on anyway.
My Computer
Beef Cake
It might fit if i made some modifications to the side panel
Get a hammer and make it fit:)
My Computer
Beef Cake
I had this same problem with my parent's pc. I was gonna replace the stock heatsink which was failing with the 212 evo since its so good for the price, but it was just a little too tall for the case, so I had to go with the TX3 instead. Welp.
Laptop - Lenovo Y50   Keyboard - Corsair K95 RGB Cherry MX Brown   Mouse - Logitech G502 Proteus Core   Mousepad - Razer Firefly
Please read the LTT Code of Conduct before submitting a post
I don't understand why people buy Hyper 212s as replacements for stock coolers on CPUs that will never be overclocked. There's coolers like the Arctic Alpine 11 and Gelid Siberian to fill that task.
"Rawr XD"
Folding 24/7, why did you think it was in the folding section?
A chainsaw also works. :D
I was thinking the same thing.
My Computer
Beef Cake
Because they're so good for the price. I would much rather pay an extra 15 bucks for a way over the top cooler than 15 bucks less for a "just good enough" cooler. If it's gonna last longer all  while being quieter and keeping my cpu cooler, why would I not go with it?
I'd actually expect the FDB fans in the Arctic Alpine 11 and Gelid Siberian to last longer then the one on the 212
"Rawr XD"
Yes, the Artic ones are good - I have a couple and lower clearance then the Evo. But, for many stores, CM stuff is always in stock, Artic, not so much. Hence why they more popular I think...
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
