What DVI cable do I buy for my monitor? DVI-D, or DVI-I? Or Single or Dual Link?
I have a GTX 770 which supports both DVI-D and DVI-I.
My monitor just says DVI.
Here's my monitor.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824014377&cm_re=benq_gl2460hm-_-24-014-377-_-Product
I was thinking of buying this cable but I don't know if it'll work.
http://www.bestbuy.com/site/insignia-6-5-dvi-cable/5886131.p?id=1219169457192&skuId=5886131&st=DVI&cp=1&lp=9
https://linustechtips.com/topic/238467-dvi-cable/
yes it will work
https://linustechtips.com/topic/238467-dvi-cable/#findComment-3271674
Here's my monitor.
That cable will work no problem since you are just running a 1080P screen @60 Hz, If you are in the USA might I suggest Monoprice cables are much better priced and fair.
https://linustechtips.com/topic/238467-dvi-cable/#findComment-3271675
Here's my monitor.
nice profile pic
Recovering Apple addict
ASUS Zephyrus G14 2022
CPU: AMD Ryzen 9 6900HS GPU: AMD r680M / RX 6700S RAM: 16GB DDR5
https://linustechtips.com/topic/238467-dvi-cable/#findComment-3271731
How can a DVI I work if my monitor doesn't have those extra pins for DVI I?
Sorry I don't really understand
I think there is some confusion there but you can get an adapter for the monitor if you already have a DVI-I cable, basically no need to worry about cables.
https://linustechtips.com/topic/238467-dvi-cable/#findComment-3271744
Oh I see, because I do not have any cables at all so was wondering what to buy.
Yeah a DVI-D cable (single link) will work for your situation so the cable from best buy will work with your monitor, I jsut suggest monoprice for it's value but they aren't selling any single link cables any more but they do have DVI-D (dual link) version for less.
http://www.monoprice.com/Product?c_id=102&cp_id=10209&cs_id=1020902&p_id=2408&seq=1&format=2
https://linustechtips.com/topic/238467-dvi-cable/#findComment-3271783
