Okay so I took my GPU out of my PC and sold it.
Now after plugging everything back in without the GPU my PC boots, but then after 6 or so seconds restarts and this loop continues.
I've plugged the display into the motherboard (cause what else can you plug it into without a GPU) and now this issue is happening.
However, even if I plug the HDMI cable out of my motherboard I still get the restarting issue.
Not sure what to do now.
Any advice?
For what it's worth there is no display on my monitor either.
Ryzen 7600X | MSI Trio X 3080 | 3440x1440p asus vg34vql1b | Antec HCG 850 | 1TB WD Blue SSD | 500GB Aorus Elite | Asus B650 Strix A
https://linustechtips.com/topic/233872-need-help-asap/
Try getting your GPU out and start it up. I suspect it's a power issue. Your GPU might be using more power than you have from your PSU
EDIT: I still suspect it is a power issue, but I'm not sure
https://linustechtips.com/topic/233872-need-help-asap/#findComment-3195981
he removed and sold it from my understanding of his post
Intel Core i5 4690K @ 4.2Ghz | Evga GTX 780 Ti SC ACX with backplate | MSI Gaming 9 AC | 8GB (2x4) Corsair Vengeance Pro Silver 2400 MHz | Corsair H105 128GB Crucial MX100 | Toshiba 2TB | Evga 750G2 | Corsair Obsidian 750d | Be Quiet Silent Wings 2 PWM (3x140mm & 3x120mm)
https://linustechtips.com/topic/233872-need-help-asap/#findComment-3195997
In his post he says he sold his gpu.
That time I saved Linus' WiFi pass from appearing on YouTube:
A sudden Linus re-appears : http://linustechtips.com/main/topic/390793-important-dailymotion-account-still-active/
https://linustechtips.com/topic/233872-need-help-asap/#findComment-3195999
this is really helpful
Oh yeah, you're right. I read it wrong and thought he bought a different GPU to put in his setup. I also saw a GPU in his PC setup, in his signature.
https://linustechtips.com/topic/233872-need-help-asap/#findComment-3196012
+1 on this. There might be a setting in the BIOS to switch between the iGPU and a dedicated one that wasn't changed.
^^^ is leading you in the correct direction. You need to ensure that iGPU/Auto is selected as the main "slot" You also have to make sure that the driver for the iGPU is installed as well. I would advise you use the VGA connector until you install all drivers needed then you can switch to the HDMI.
Any advice?
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/233872-need-help-asap/#findComment-3196405
