Hi I'm looking to build a pc in the 500$ price range. This is the first budget pc I have built so I need all the imput I can get.
I already have a mouse keyboard and I will be using my tv as a monitor. The operating system must be included. Also I am from Canada.
The games I will be playing mostly is runescape and some blizzard games like star craft and the new wow expansion.
https://linustechtips.com/topic/232442-need-help-with-new-build/
CPU: AMD A10-5800K 3.8GHz Quad-Core Processor  ($104.98 @ DirectCanada)
Motherboard: Asus A78M-E Micro ATX FM2+ Motherboard  ($55.00 @ NCIX)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory  ($87.62 @ DirectCanada)
Case: Zalman Z5 Plus ATX Mid Tower Case  ($44.99 @ Memory Express)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($44.99 @ Memory Express)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($97.98 @ DirectCanada)
Total: $489.54
Generated by PCPartPicker 2014-10-13 12:49 EDT-0400
"Rawr XD"
https://linustechtips.com/topic/232442-need-help-with-new-build/#findComment-3177463
Where are you located?
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/232442-need-help-with-new-build/#findComment-3177516
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($71.48 @ DirectCanada)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($54.50 @ Vuugo)
Memory: Corsair Vengeance LP 8GB (2 x 4GB) DDR3-1600 Memory  ($79.99 @ Memory Express)
Video Card: PowerColor Radeon R9 270 2GB TurboDuo Video Card  ($139.99 @ NCIX)
Case: BitFenix Comrade ATX Mid Tower Case  ($42.99 @ NCIX)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply  ($49.98 @ Newegg Canada)
Total: $590.89
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/232442-need-help-with-new-build/#findComment-3177525
Total: $590.89
Cograts on 2k post...
Also...
Compatibility Notes
  • icon_info_sgl.gifBitFenix Comrade ATX Mid Tower Case has front panel USB 3.0 ports, but the MSI H81M-P33 Micro ATX LGA1150 Motherboard does not have onboard USB 3.0 headers.
  • icon_info_sgl.gifSome Intel H81 chipset motherboards may need a BIOS update prior to using Haswell Refresh CPUs.
Because he had a hard drive.
https://linustechtips.com/topic/232442-need-help-with-new-build/#findComment-3177535
Also...
Compatibility Notes
thanks and yea youcan update it and it can now overclock and you dont need usb 3
https://linustechtips.com/topic/232442-need-help-with-new-build/#findComment-3177546
Motherboard: MSI Z87-G41 PC Mate ATX LGA1150 Motherboard  ($83.98 @ Newegg Canada)
Total: $585.01
Generated by PCPartPicker 2014-10-13 12:57 EDT-0400
https://linustechtips.com/topic/232442-need-help-with-new-build/#findComment-3177583
PCPartPicker part list: http://ca.pcpartpicker.com/p/7fYRqs
Price breakdown by merchant: http://ca.pcpartpicker.com/p/7fYRqs/by_merchant/
Motherboard: ASRock H81M-HDS Micro ATX LGA1150 Motherboard  ($57.00 @ Vuugo)
Memory: Crucial 8GB (1 x 8GB) DDR3-1600 Memory  ($78.35 @ DirectCanada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($53.98 @ DirectCanada)
Video Card: MSI Radeon R7 250X 1GB Video Card  ($97.25 @ Vuugo)
Case: Zalman Z5 ATX Mid Tower Case  ($39.99 @ Memory Express)
Power Supply: EVGA 430W 80+ Certified ATX Power Supply  ($29.99 @ Memory Express)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($104.98 @ Newegg Canada)
Total: $533.02
Generated by PCPartPicker 2014-10-13 13:00 EDT-0400
A little over $500 but I managed to include Win 8.1, 8GB RAM and 1 TB HDD.
https://linustechtips.com/topic/232442-need-help-with-new-build/#findComment-3177612
