I am building a computer and I'm not sure what wattage of power supply I should get my build is
GPU ASUS STRIX-GTX980
CPU Intel Core i5 4690K
Motherboard ASUS MAXIMUS VII HERO
SSD Crucial MX100 SSD 512GB
Cooler CORSAIR Hydro Series H110
Case Corsair Graphite Series 760T
RAM CORSAIR Vengeance Pro 8GB (2 x 4GB)
I want to be able to add a 2nd gpu upgrade to a i7 4790k add a tv tuner capture card and wifi card
https://linustechtips.com/topic/232010-power-supply/
------------derp
anything above 600 watts
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/232010-power-supply/#findComment-3171832
I'd sugest a 850w PSU
that would be for 4 way 980's with an overclocked 5960x with like 90 fans
https://linustechtips.com/topic/232010-power-supply/#findComment-3171857
A decent 700w psu would be plenty.
https://linustechtips.com/topic/232010-power-supply/#findComment-3179866
