The ram is too expensive and you don't need 16gb for gaming.Get a cheaper ram and get a 290x
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
https://linustechtips.com/topic/231453-how-is-my-build/#findComment-3164601
$2000 and a 760? I got a 780Ti for $2000.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/231453-how-is-my-build/#findComment-3164611
My budget is max 23 hundred and I want the 16 gigs for editing and photoshopping and rendering while gaming is it still too much?
Will you really be rendering AND gaming at the same time? I would recommend sticking with 8GB of ram for now and seeing how well that does for you. If you find you really need more ram, it's as easy as just plugging in some more.
https://linustechtips.com/topic/231453-how-is-my-build/#findComment-3164644
I'm secretly pewdiepie
https://linustechtips.com/topic/231453-how-is-my-build/#findComment-3164658
Bam, a better build that's cheaper.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($234.96 @ NCIX US)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($97.16 @ Amazon)
Motherboard: Gigabyte GA-Z97X-Gaming 5 ATX LGA1150 Motherboard  ($129.99 @ NCIX US)
Memory: Kingston Fury Black Series 16GB (2 x 8GB) DDR3-1600 Memory  ($140.99 @ Newegg)
Storage: Crucial M500 240GB 2.5" Solid State Drive  ($109.99 @ Adorama)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($53.99 @ Amazon)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card (2-Way SLI)  ($349.99 @ Amazon)
Case: NZXT Phantom 630 Windowed Edition (Black) ATX Full Tower Case  ($149.99 @ Amazon)
Power Supply: EVGA 850W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($89.99 @ NCIX US)
Optical Drive: Asus DRW-24F1ST DVD/CD Writer  ($14.99 @ Amazon)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($89.99 @ NCIX US)
Wireless Network Adapter: Asus PCE-AC68 802.11a/b/g/n/ac PCI-Express x1 Wi-Fi Adapter  ($96.99 @ Amazon)
Keyboard: Corsair K70 RGB Wired Gaming Keyboard  ($169.99 @ Amazon)
Mouse: Corsair Vengeance M95 Wired Laser Mouse  ($57.99 @ Newegg)
Total: $2136.99
Generated by PCPartPicker 2014-10-11 18:18 EDT-0400
https://linustechtips.com/topic/231453-how-is-my-build/#findComment-3164684
